Electric Fan Swap - How to Mount your new fan. Make a shroud! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Electric Fan Swap - How to Mount your new fan. Make a shroud!
Rough Country Lift Kits and Parts!Bds fox ipf 2.0 racing series shocks now available at rock20 Ton Press Brake DIY Builder Kit @ Swag Off Road
Unread 05-08-2007, 10:56 AM   #1
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
after running the ran with those cheap zip ties that went through the radiator for 3 years and eventually springing a leak from the friction of the fan on the fins, it was time to get a new radiator and a REAL mount for the fan.
lowe's.... 28x24" 16 gauge sheet metal $35
lowe's.... 4 x 1/4" x 1.5" long 28 TPI allen bolts w/nuts
lowe's.... 6 14mm self tapping screws (should have used nuts and bolts but i was lazy)
cut sheet metal 18" x 23 3/4" w/ fancy plasma cutter
lay fan centered on sheet metal. trace with sharpie.
drill 4 holes for bolts that will hold fan to sheet metal.
find something round to trace with the plasma so air can flow through the fan blades (had a viper flywheel handy that was the perfect size)
plasma circle in sheet metal
paint (i used rubberized undercoating from car quest)
bolt fan to sheet metal.
use your angle grinder to cut the bolts flush with the end of the nuts so they don't go through the radiator and cause a leak
lay down the fan and shroud on the radiator and self tap three screws in each side (note there are holes in the radiator so don't waste a screw going through one of those)
wa-lah!
sorry no pics of the process, i was busy making it... not thinking of taking pictures.
it pulls air across the entire radiator and held my temps down steady at 180 degrees ALL DAY saturday while wheeling up in the mountains.
-Erik <--- using a 16" Imperial fan from advance auto parts ($70)
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS!
Big-n-Broke-YJ is offline   Reply With Quote
Unread 05-08-2007, 11:24 AM   #2
jeepnmike
Well aint that perdy. Nice job!
'95 YJ- 1.25" BL, 31" bfg's, black cragars, herc'd tub. sold
'99 TJ Sport- 35's, 8.8, 4.88s, 5" RC LA, JB SS SYE, UFC TT, HD steering
jeepnmike is offline   Reply With Quote
Unread 05-08-2007, 04:51 PM   #3
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
thanks.
it's simple, cheap, and works great.
i've seen about 20 or so people who have installed electric fans on their wranglers. of those i've seen 1 with a shroud and 2 that were mounted well with a method OTHER THAN the nylong zip tie things..... figured this would be a good way to show everyone how easy it would be to mount your fan(s) the RIGHT way......
