Electric Fan Install Write up (Taurus, Mark VII) - Page 6 - JeepForum.com
post #76 of 165 Old 10-20-2010, 11:30 AM
fwb35
How big of a electric fan can you put on a 2.5, will a 14 inch fit? a 16 inch?
fwb35 is offline
post #77 of 165 Old 12-09-2010, 09:18 PM
Sofla1984
nice write up! I will surely be doing this ASAP! Those "BeCOOL" and "FLEXaLITE" ones seem to be way over priced!
Sofla1984 is offline
post #78 of 165 Old 03-21-2011, 02:15 PM
95greenrio
Is the LED relay also a 50A Bosch or do you need to use a different one?
1995 YJ Rio Grand - work in progress
95greenrio is offline
post #79 of 165 Old 03-21-2011, 02:32 PM
Que89YJ
if its just powering the LED only then it can be a standard auto relay.
Que89YJ is offline
post #80 of 165 Old 03-22-2011, 11:23 PM
95greenrio
Thanks for the reply Que89YJ.
What size wire did you use? Would 8AWG be too thin?
post #81 of 165 Old 03-23-2011, 06:49 AM
Chugger
Will it work?
Will this fan be enough to cool a 5.7 with a TPI?
Chugger is offline
post #82 of 165 Old 03-24-2011, 12:30 PM
Que89YJ
Yes 8 guage will work and yes, just make sure you wire in the high speed switch. Im not sure if the low speed would do it on a hot day with the 5.7L but plenty of racers use it on the 350.
Que89YJ is offline
post #83 of 165 Old 07-17-2011, 08:01 PM
Louie4
"You pass butter"
Louie4's Avatar
I picked up this stuff at the pull-a-part this afternoon. My buddy and I both got a Taurus fan and a 50 amp relay out of a Volvo. I believe it was a '94 760. We tested the fans and the relays when we got home and everything worked. I spent $20.16 for the fan and the relay.
All I need now is a thermostat, sensor probe, circuit breaker, wire and a switch. I only plan on using the low speed for now.
I also found this on Amazon. It might be too cheap but I only want to use the probe and thermostat:
http://www.amazon.com/Hayden-Inc-3653-Cooling-Control/dp/B000C39C6I
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #84 of 165 Old 07-17-2011, 08:29 PM
Louie4
"You pass butter"
Louie4's Avatar
Found this:
Looks promising. I would like to pick up something at the local autoparts stores but I've had trouble finding stuff online.
http://www.google.com/products/catal...d=0CIABEPMCMAA
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #85 of 165 Old 07-18-2011, 08:13 AM
Que89YJ
The Hayden is the one i used. No issues.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #86 of 165 Old 07-18-2011, 09:53 AM
Louie4
"You pass butter"
Louie4's Avatar
Sweet. Looks like I'll be putting an order in to Amazon.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #87 of 165 Old 07-18-2011, 08:17 PM
Louie4
"You pass butter"
Louie4's Avatar
Well I started working on my fan swap and I ran into a snag. It seems I'm having some fitment issues. I've seen others who were able to fit the fan in with next to no space but it fit. I wonder if I need to swap in a cherokee water pump. I have a pulley and old pump at home.
I can still trim the shroud on the fan to get a little more clearance. The main issue is the main water pump shaft. I could always trim it down.
Any ideas?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #88 of 165 Old 07-18-2011, 08:22 PM Thread Starter
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
From the research that I've done, the XJ water pump actually spins in the opposite direction. If you find one that doesn't, post it up.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is online now
post #89 of 165 Old 07-18-2011, 08:34 PM
Louie4
"You pass butter"
Louie4's Avatar
Found it.
Post #15
http://www.jeepforum.com/forum/f12/t...ld-fan-957598/
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #90 of 165 Old 07-18-2011, 09:30 PM Thread Starter
Mr.B
Mr.B's Avatar
You may be right, but the XJ water pumps I've seen, I have an '89 by the way, don't have the clutch fan attached to them. That's what makes them skinnier. This one looks like it did.
Ham license:
Everyone is Welcome
Mr.B is online now
Taurus Electric Fan Que89YJ YJ Wrangler Technical Forum 5 06-17-2009 01:29 PM
Taurus Electric Fan in YJ JeepsOLot YJ Wrangler Technical Forum 2 02-25-2009 07:39 PM
Electric Fan>Taurus>2.5L - Anyone run it? MikNov TJ Wrangler Technical Forum 2 12-31-2008 01:53 PM
Mark VII/Taurus Install Question Jeebs YJ Wrangler Technical Forum 8 03-25-2008 06:42 PM
write up for electric fan install sandman'sjeep YJ Wrangler Technical Forum 3 06-07-2006 12:02 PM
