Electric Fan Install Write up (Taurus, Mark VII) - Page 2 - JeepForum.com
post #16 of 165 Old 07-18-2009, 10:59 AM
trw
2011 JK Wrangler
I have to ask, with the stock 75amp alternator (with the 4cyl), do you have any problems running accesories while the fan kicks on? such as lights or the heater or a winch?
my worries about my alternator have been the only thing stopping me from doing the taurus fan mod.
Jeep garage:
2011 Jeep Wrangler JK - 33" BFG KM2s, 2.5" RC BB, ARB bumper, IPF 900XS, Superwinch EPI 9.0, AEV Snorkel
1995 Jeep Wrangler - 4 cyl, 2.5" lift, BFG AT 30s, Ford 8.8, SYE+CV, AX15 swap, ARB snorkel, Aussie locker + loads more - sold
1978 Jeep CJ-7 - 304 V8, TH400 auto and quadratrac
2007 Jeep Liberty - Mother's Jeep, BFG ATs and....mud?
trw is offline
post #17 of 165 Old 07-19-2009, 05:24 PM Thread Starter
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
I believe the stock alternator is 90 amps. But if your concerned, check out the link below. This was the easiest mod I have ever done to the Jeep.
http://www.bc4x4.com/tech/2004/jeepalt/
Oh and I have only ever had to run high speed twice. Both times the Jeep was fully loaded and it was a steep incline.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #18 of 165 Old 09-18-2009, 04:13 PM
haulincats
does the electric fan push air or pull air?
What does the stock mechanical fan do, push or pull?
Thanks,
Vance
haulincats is offline
post #19 of 165 Old 09-18-2009, 05:20 PM
YJake
They pull air like any other fan?
I put a 4.0TB in at about the same time as I put the fan in a couple months ago and it works great. I know for a fact that I have more pep off of the starting line and it accelerates quicker as well. I have the 70Amp alternator and the guage always reads with the needle at the center, so it seems to be plenty to run the fan on low. (The needle twitches when I turn the fan on but goes right back to normal)
Now, I wired the fan to my ignition so it only runs when the key is in the "On" position. I also put in a toggle switch so that I can kill the fan when I go underwater, or while I'm on the highway (I noticed that just driving 60-70mph keeps my engine cool enough without the fan on even in summer! ).
I'm going to climb some hills tomorrow that I haven't done since before the fan/TB mods. Can't wait to see if it climbs easier!
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline
post #20 of 165 Old 09-18-2009, 07:29 PM
buckshot500
I have a sable fan, the shroud has a kind of ">" shape on it. It is too thick to fit my 4.2L between the radiator & bolted pulley. I'm thinking the one pictured might be a little bit thinner.
Anyone do this mod to a 4.2L & remember what vehicle (Make/model/year) the fan is out of?
Originally Posted by 5point1 View Post
Well after I drained the oil, I ran water through the engine to clean out the gunk. (the guy who owned before me obvioulsy didn't know how to maintain the engine).
90YJ98XJ
buckshot500 is offline
post #21 of 165 Old 09-27-2009, 06:12 PM
bloopy901
My fan finally installed!
Here is the finished product...
bloopy901 is offline
post #22 of 165 Old 09-27-2009, 08:30 PM Thread Starter
Mr.B
Mr.B's Avatar
Great job Bloopy. That looks like a Mark VII fan. Are you eventually going to run the wires in your electrical box through the holes you drilled, and then close it up?
Ham license:
Everyone is Welcome
Mr.B is offline
post #23 of 165 Old 09-27-2009, 09:06 PM
bloopy901
I want to. Hopefully this weekend. I want to clean it up and all that.
post #24 of 165 Old 09-28-2009, 12:02 AM
wfcxleatherneck
1993 XJ Cherokee
How did you get the prob through the rad? ( sorry if this is a total newb question)
Wouldnt that cause it to leak?
wfcxleatherneck is offline
post #25 of 165 Old 09-28-2009, 07:39 AM
Que89YJ
The probe pushes through the fins just below the top hose so it gets the temp from the incoming water into the radiator. There are alot of kits available. I got mine from autozone for 35 dollars. Easy to install and works very well. I wired up the low side automatic and high side and off through a 2 position switch. I was using the stock alternator when I hooked it up for the first 2 months with no problems. I went to the alternator mod after because I am getting ready to mount a winch. The stock alternator didnt have any problems with only the fan mod and a decent stereo added. Great write up!
Que89YJ is online now
post #26 of 165 Old 09-28-2009, 07:51 AM
jbolty
jbolty's Avatar
I made the openinging in the fins a little oversize and packed it with jb weld. the probe does not flop around and it will certainly transfer the heat measurement better.
jbolty is offline
post #27 of 165 Old 09-28-2009, 08:11 AM
bloopy901
I stuck a small philips screw driver in first to make a small hole for the probe to fit into. As for the jbweld that is a good idea ill have to try that.
post #28 of 165 Old 11-30-2009, 03:17 PM
njmrenegade
my mom has a 1994 taurus shes trying to sell, just wondering if it would be worth it to steal the fan, i dont really crawl or off road for that matter, should i do this anyway?
njmrenegade is offline
post #29 of 165 Old 11-30-2009, 05:03 PM
davidselite737
Ill post pics of mine sometime this week. I matted the taurus 3.8L fan to the stock 2.5L jeep fan shroud to cover more surface area of the radiator. And plus I could use the stock bolt locations to hold it to the Rad. Ran it offroad this past Saturday. had no issues whatsoever. Only have the low speed on an adjustable thermostatic relay. And wired the 12 volt trigger wire to a rocker switch in the cab to be able to turn it off when I wanted. Works flawlessly and after adjustment keeps the water temp gauge between 180-210 always.
" The path of least resistance, is the path of the loser"
davidselite737 is offline
post #30 of 165 Old 11-30-2009, 10:50 PM
bloopy901
I don't off road much my self. Maybe once a month but still the electric fan is a good mod to do. Lets my jeep warm up faster for those cold mornings. Plus its easy as hell to do.
Taurus Electric Fan Que89YJ YJ Wrangler Technical Forum 5 06-17-2009 12:29 PM
Taurus Electric Fan in YJ JeepsOLot YJ Wrangler Technical Forum 2 02-25-2009 06:39 PM
Electric Fan>Taurus>2.5L - Anyone run it? MikNov TJ Wrangler Technical Forum 2 12-31-2008 12:53 PM
Mark VII/Taurus Install Question Jeebs YJ Wrangler Technical Forum 8 03-25-2008 05:42 PM
write up for electric fan install sandman'sjeep YJ Wrangler Technical Forum 3 06-07-2006 11:02 AM
