Electric Fan Install Write up (Taurus, Mark VII) - Page 10 - JeepForum.com
post #136 of 165 Old 06-09-2012, 07:52 AM
YJ43
Thanks Que! Let me know when you're in Chicago next, I owe you a few beers!
1995 YJ: 4.0L I-6 and AW-4 trans; CJ front clip; SOA front, 4-link in rear; 8.8 rear w/ Detroit locker; 4.56 gears; TJ front shafts; SYE; 1" Body lift; JB4x4 hi-steer; Ford Taurus fan; B&M Hi-Tek trans cooler; 35" Procomp MT on aluminum wheels
YJ43 is offline
post #137 of 165 Old 07-07-2012, 03:29 PM
YJ43
I seem to be having issues running this...I bought the $35 Hayden controller that has it's own built in relay...I had it just running through that on low speed for a little bit and it worked. Now I'm trying to wire in high-speed as well following the diagram on page 1. When I connect the controller similar to the diagram on page 1 to pin 86 on the low speed relay, I only get high speed...is this because I need to eliminate the extra low-speed relay that I've added and just use the one included in the controller? This probably isn't making sense, but this is the one I have:
http://www.haydenauto.com/New%20Prod...r/Content.aspx
The way that I have this set up is the orange wire going to pin 86 on another low speed relay and then the high speed wired up like the diagram on page 1...any thoughts as to what I'm doing wrong.
YJ43 is offline
post #138 of 165 Old 07-07-2012, 04:51 PM
YJ43
Figured it out...with that controller, you don't need another relay, just take the low speed wire to the ignition wire and then run the high speed on it's own higher amp relay to the wire on the high speed switch. I was trying to use another relay for the low speed, which isn't necessary (essentially 3 relays), if that makes any sense, lol.
YJ43 is offline
post #139 of 165 Old 07-07-2012, 09:06 PM Thread Starter
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
That controller looks like it has a second relay for high speed. I'm glad you figured it out. When I did this back in 2007, there were no controllers like that.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is online now
post #140 of 165 Old 07-08-2012, 07:35 AM
Que89YJ
With the low speed already turning the fan the high speed doesn't generate the 80 amps in rush so you just need to make sure the relay is rated for 40 amps. I still haven't needed to wire in the high speed on mine. The low speed moves enough air to cool it.
Que89YJ is offline
post #141 of 165 Old 07-08-2012, 09:38 AM Thread Starter
Mr.B
Mr.B's Avatar
Yeah, I've only had to use high speed a couple of times. Only on a steep grade, fully loaded.
Ham license:
Everyone is Welcome
Mr.B is online now
post #142 of 165 Old 09-03-2012, 05:09 PM
99_green_tj
can you just wire the fan straight to a toggle switch and cut it off and on with that? I looked through thred and didnt see anything that stood out.
99_green_tj is offline
post #143 of 165 Old 09-03-2012, 05:41 PM
kjg26
kjg26's Avatar
No. It would seriously overload most switches
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #144 of 165 Old 09-03-2012, 11:10 PM Thread Starter
Mr.B
Mr.B's Avatar
Like kjg26 said. You would at least have to run it through a relay also. But why would you want to do that? When I'm on the road, I have most of my attention on all those idiot drivers out there. When I'm on the trail, I'm looking at the next rock I'm going to climb. It only takes a few minutes of distraction, and you are overheating your engine. why would you want to risk that?
Ham license:
Everyone is Welcome
Mr.B is online now
post #145 of 165 Old 11-28-2012, 08:48 PM
Treton
So, I'm sorry if this was expressed previously and I missed it but. I'm working on a little buggy type thing and if I wanted to set this up so so it just runs full time low with a on/off bypass. Could someone also give me the dimensions of the Taurus unit?
Treton is offline
post #146 of 165 Old 03-15-2013, 07:08 AM
CaveyDM
Has anyone done this Mod to a TJ/LJ 4.0?
What would be the disadvantages?
I see the advantage with water fording and what not.
Are there any other plusses to switching things out to an electric Fan on a 4.0?
Very good write up that looks easy to understand.
Best Regards,
Dale
2006 2DR LJ RUBICON UNLIMITED / Old Man Emu (OME) 2.5" HD Lift / ARB Quadratec Edition Front Stubby / LOD Signature Series Rear Bumper & T/C
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
CaveyDM is offline
post #147 of 165 Old 03-15-2013, 07:32 AM
NHfireLJ
NHfireLJ's Avatar
Consider usuing a volvo relay if you do this. Much simpler IMHO
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #148 of 165 Old 03-15-2013, 07:42 AM
CaveyDM
Good note to add to my list of info on this subject. Still not sure I want to do this as its pretty invasive. Im not finding a lot of TJ folks that have made this leap, but I'm not done looking around yet either.
Best Regards,
Dale
CaveyDM is offline
post #149 of 165 Old 08-26-2015, 04:23 PM
TraceNalf
Great write up. I just bought the electric fan and it will be going in tomorrow. Thanks a bunch
TraceNalf is offline
post #150 of 165 Old 04-24-2016, 08:54 PM
Mahanoy
Hell . I've just got the fan and such and wired up the relays to makw them work. I've tried to use a diode but I hooked it up wrong and blew it up. How exactly did you hook up the diode and where? Shouldn't the high and low wires have a diode to stop the gererator effect while freewheeling? Do I need a diode to handle 40 amps? I can understand schematics but I'm not to familiar with electonics so please help me. Do the bosh relays have built in diodes? Thanks
Mahanoy is offline
Taurus Electric Fan Que89YJ YJ Wrangler Technical Forum 5 06-17-2009 01:29 PM
Taurus Electric Fan in YJ JeepsOLot YJ Wrangler Technical Forum 2 02-25-2009 07:39 PM
Electric Fan>Taurus>2.5L - Anyone run it? MikNov TJ Wrangler Technical Forum 2 12-31-2008 01:53 PM
Mark VII/Taurus Install Question Jeebs YJ Wrangler Technical Forum 8 03-25-2008 06:42 PM
write up for electric fan install sandman'sjeep YJ Wrangler Technical Forum 3 06-07-2006 12:02 PM
