-   -   Electric Fan Install Write up (Taurus, Mark VII) (http://www.jeepforum.com/forum/f12/electric-fan-install-write-up-taurus-mark-vii-506679/)
Mr.B 01-12-2008 01:40 PM
I started this about a year ago, but never finished it. Life kept getting in the way.
Iíve been looking for ways to help out my poor little 2.5L engine. There isnít much out there. If I could just get a little more MPH on the freeway, Iíd be happy. The electric fan conversion seemed to be an inexpensive way to help. I also liked the idea of being able to control the fan when the need arises. When rock crawling, I have noticed temperature rising to over 210. There wasnít much I could do about it before, but now I can switch the fan to high if I need to. Although river crossings are rare here in Northern California, they do happen. Now I can turn off the fan before I go in.
The first thing I needed was a Fan. I went to the local Pic and Pull and started searching. The type of 2 speed fan that is needed is on a 3.8L V6 Taurus from 1990 through 1995, I believe. Well there were plenty of 3.8L Taurus junkers out there, but of dubious fan quality. Then I came upon a 1994 Mercury Cougar with a 4.6L V8. You could tell the car was well taken care of by the owner until someone T-boned it. The cowling was bigger than the Taurus fan, and the blades were different. But the motor was the same. It was a Lincoln Mark VII fan.
http://i44.photobucket.com/albums/f1...n/P1010028.jpg
http://i44.photobucket.com/albums/f1...n/P1010030.jpg
When I got it home, I removed my OEM shroud, and placed fan up against the radiator, and it was a perfect fit. It covered the core completely. And it sat perfectly in between the upper and lower lips. Since I am around fourth owner of this Jeep, I can't be sure if the radiator is comparable to OEM. But there doesn't seem to be anything out of the ordinary though. Notice the belt routing picture on the top. I took a picture of the original, and printed it on label paper, then covered it with packing tape. It still looks the same after 1 1/2 years.
http://i44.photobucket.com/albums/f1...n/P1010033.jpg
Since it was such a perfect fit, mounting it was a piece of cake. Because there was no downward stress from sitting on the lip, I could use pipe strapping and dry wall screws (I think) to mount it to the original shroud mounting holes. I had to drill out the holes on the pipe strap a bit, to fit the original bolts.
http://i44.photobucket.com/albums/f1...n/P1010036.jpg
The next issue was controlling the fan. I did alot of research, both here and on other sites. There were alot of diagrams out there. I took what I liked and designed my own.
http://i44.photobucket.com/albums/f1...PEEDFANa-1.jpg
The two fan relays are 50A Bosch relays, that I purchased from this site. They are a wholesaler, so if you want to purchase from them, you have to register as a company.
http://www.waytekwire.com/
The switch is a high current, on-off-on switch that I bought from a local electronics store. The diode is there to reduce back flow current to the relay when the fan is off, but spinning from air circulation. I got it at the same place as the switch. If you want to buy one, just bring the part number into an electronics store, and they can match it.
Now I had to buy a controller. Since money was tight at the time, I bought a cheapo Advance Auto controller. You can use any controller you want, the diagram will still work. Since my controller wasn't waterproof, I had to find a way to seal it up. An outdoor electrical box was the answer. With some bending and coaxing, I was able to get the mounting bracket that came with it in the electrical box. There were only two wires coming out of the box. One was the probe and the other was the positive. I sealed the hole with RTV afterwards. Since I mounted to the wheel well, I used it as the ground.
http://i44.photobucket.com/albums/f1...n/P1010016.jpg
Here is a pic of everything mounted on the wheel well.
http://i44.photobucket.com/albums/f1...n/P1010039.jpg
The stupid air horns aren't there anymore.
Because the cowling on this fan is such a tight fit and narrow, I decided to run the probe from the front of the radiator. Here is a pic of the probe entering the front of the radiator. And another one of it coming out the rear.
http://i44.photobucket.com/albums/f1...n/P1010027.jpg
http://i44.photobucket.com/albums/f1...P1010018-1.jpg
I used some heat shrink tubing on the front and the back, with black heat resistant zip-ties to hold them in place.
With everything mounted and in place, it was time to adjust the controller. Because it was a cheapo, it took me awhile to get it right. While I was testing, I noticed that it was shutting off rather fast. I figured that the fan was so good, that it was cooling off the probe also. To solve this problem, I discovered that the distance between the cowling and the radiator was exactly the length of an old 35MM plastic film canister. So I attached it to the cowling so it covered the probe on the backside. This worked well since the probe was inserted from the front. Sorry I don't have any pictures of the canister mounted. I used a Fluke temp probe to check the function of the controller. The fan kicks in at around 198 degrees, and shuts off at 147 degrees. That is the temperature of the front of the radiator where the probe is, not the temperature inside the engine. In the year and a half that I have had it installed, I have not had a single problem with it. The only time I have ever had to switch to high was climbing the steep grade driving up to the Barrett Lake trail with a fully packed Jeep. If you have any questions, feel free to PM me. Here's a pic of everything installed.
http://i44.photobucket.com/albums/f1...n/P1010034.jpg
swedishdwarf 01-15-2008 06:11 PM
I did this same mod to my 4.0L yesterday. Although it's a pretty tight fit (<3/8" clearance), you can do this to a 4.0L.
Mr.B 01-15-2008 08:28 PM
Was it a Taurus fan? And did you rotate it upside down?
sstaurus 01-15-2008 08:59 PM
Do you have to use that probe in the radiator? Or is there a better way to tap right into the coolant in the block... I'd like to do this to my 2.5:thumbsup:
Mr.B 01-15-2008 09:44 PM
I think Drew2000 has a different controller. do some research on electric fan controllers. Mine cost $17. I think his was @ $150.
swedishdwarf 01-15-2008 11:54 PM
Yes, and yes. Even so it barely fits.
There's a way, but it's a lot more work than this. I have put electric fan systems on Chevy 350s and used a Dodge thermal switch ( I don't remember what model Dodge it fits, but I can probably find out if anyone cares) that threads right into the thermostat housing. I'm sure you could do something like that, but I don't think you can buy a thermostat housing for the Jeep 2.5L with a threaded hole already in it.
If there are any unused plugs that go in the water jacket I'm sure you could make it work. Otherwise you would have to make someplace for the switch (or probe, if you like the adjustable controllers) to go.
FF151DJG 06-16-2008 08:28 AM
horse pawer
did it give more horsepower and what do your temp run
Brads_nky_yj 06-16-2008 08:37 AM
I would love to do this on my 4.0, but I have no idea how to read and understand that wiring diagram, I geuss I just hate wiring that much. If I get all the parts I could figure it out probably.
bloopy901 07-17-2009 12:22 PM
Thanks for the great step by step!
I dont want to steal any of your credit for any of this but, I made the schematic a little easier for noobs like me at reading schematics... I just added some color :D
It helped me to differenciate between connections and what not. Maybe it will help other people.
http://i552.photobucket.com/albums/j...PEEDFANa-1.jpg
:cheers2:
Louie4 07-17-2009 12:38 PM
Nice write-up. I tried this mod several years ago. I snagged a taurus fan from a junkyard and took it home. I tried to fit the fan down in between the radiator and waterpump pulley but it wouldn't fit. I saw someone else said they were able to make it work. Maybe I had the wrong fan motor of something, because it seemed to stick out a little. The one above doesn't seem to as much.
I got to thinking though, how much extra power does the give? Is it noticeable in the seat? My 4.0 doesn't run hot like it use to after I replaced the radiator for the 3rd time. So cooling is not an issue. I guess something to think about though. How much was the wiring kit for it?
Mr.B 07-17-2009 06:37 PM
:cheers2:
Nice job on the color. It doesn't do much for me, but if it helps others, it's great.
It might not give you any noticable power with your 4.0, but it will probably help in cooling at low RPM's, like rock crawling.
River Ryder 07-17-2009 08:07 PM
I ran a 1.5" pipe with a temp switch in line with the top rad hose. Just trimmed a section out of it. The sensor was out of a 95 caprice, kicked in at 195. The fan was out of a 88' Firebird (given to me from a friend).
Worked pretty good, I noticed the biggest difference on the trail while doing steep climbs, engine stayed nice and cool. As far as a performance aspect, I didn't notice too much other than it seemed to wind up a little faster not very noticeable. Those clutch fans are heavy.
The best thing about it; warms up really fast in the winter. That's big here in the snow belt of CNY:tea:
VACJ5 07-18-2009 08:10 AM
I have a 2 speed taurus fan in my garage... I want to have it temperature controlled but also have a 3 way switch to override it when needed (including turning it off). Is that how you guys have it setup? (I too am a wiring moron)
Tomb Raider 07-18-2009 08:17 AM
It should be noted........
Taurus fans on "high" can draw more than the 50 amps at startup. I used one for quite some time and went through a couple relay's. In the end, the fan blew hard enough on low that I removed the high circuit. It kept my 4.0L cool.
YJake 07-18-2009 10:46 AM
Very nice!
I'd love to do this to help out my little 2.5.
The time now is 12:37 PM.
