Electric fan? - JeepForum.com
post #1 of 12 Old 03-23-2016, 05:18 PM Thread Starter
AmnNeff
1975 CJ5
Electric fan?
Alright I need some help with this stupid fan. I'm doing a 302 conversion in my 88 yj. Now most of the stuff came from novak for this build. It's a Spal fan and spal relay wired exactly how the diagram says to. But when the key is turned to the on position the fan runs full blast. Any suggestions on what to trouble shoot first?
Sent from my SM-G928V using Tapatalk
AmnNeff is offline
post #2 of 12 Old 03-23-2016, 07:10 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
If there is only one relay, there's only one speed. How many wires are coming out of the fan?
EDIT: I guess I should have asked what the perceived problem is? The key is on, the fan runs. If you don't want it to run while starting you'll have to find a 12v source that kills when the ignition is engaged (like the radio does) and loop it in there. My LJ had an e-fan that was wired to a switch on my dash. It was either on full or off. So I ask you, what's the issue?
91 YJ "Alice" 4.0L, AX-15, NP 231 w/HnT Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #3 of 12 Old 03-23-2016, 08:00 PM Thread Starter
AmnNeff
1975 CJ5
Well according to the spal directions it's only supposed to kick the relay once the switch reaches 185 so I figured it shouldn't run until it hits that correct? Or does it have to actually be running to do this. And it's only two wire from the fan hot and ground.
AmnNeff is offline
post #4 of 12 Old 03-23-2016, 08:01 PM Thread Starter
AmnNeff
1975 CJ5
I just tried changing the relay and the switch same problem so I must have the wrong ignition wire.. the harness was all chopped up when I got it so I'm not sure what's what haha.
AmnNeff is offline
post #5 of 12 Old 03-23-2016, 08:17 PM
jsawduste
2006 YJ Wrangler
The relay is wired wrong haha.
Fan should not come on until the temp sensor reaches 185 and completes a circuit to ground.
jsawduste is offline
post #6 of 12 Old 03-23-2016, 08:25 PM Thread Starter
AmnNeff
1975 CJ5
Yeah I figured must be the ignition wire I'm using.. because the other four are pretty straight forward 12 from battery, red hot from relay to red fan. Ground the fan, gray to switch, orange to ignition. So I need to find a wire that only turns on when I turn the ignition to start position? Because it's on a wire now that comes on when they key is in the run position.
AmnNeff is offline
post #7 of 12 Old 03-23-2016, 08:49 PM
jsawduste
2006 YJ Wrangler
30 main power to relay from battery
85 switched power
86 ground (fan thermo switch)
87 to fan positive
Fan ground to separate ground
post #8 of 12 Old 03-23-2016, 09:27 PM
Luuca
Luuca's Avatar
85 switched power
87 to fan positive
Where did he say he has a thermo switch? Did I miss it?
YJOTM never
Luuca is offline
post #9 of 12 Old 03-23-2016, 09:29 PM
jsawduste
2006 YJ Wrangler
Thinking post 3
post #10 of 12 Old 03-23-2016, 09:30 PM
jsawduste
2006 YJ Wrangler
Post 6 also
post #11 of 12 Old 03-23-2016, 09:38 PM Thread Starter
AmnNeff
1975 CJ5
Post 6 and 3.. it's in the intake manifold of the 302.
AmnNeff is offline
post #12 of 12 Old 03-23-2016, 09:46 PM
jsawduste
2006 YJ Wrangler
Run the wires as posted earlier. Unless the switch is faulty it will work the I posted it.
