Elecrical problem! - Page 2 - JeepForum.com
post #16 of 17 Old 08-12-2011, 09:23 PM
Que89YJ
I still think its either power to the pdc or the pdc itself. Check the big 40 amp fuses in the pdc and the wiring underneath going to it.
Que89YJ is offline
post #17 of 17 Old 08-12-2011, 09:24 PM
UMDJesse
Im not sure I follow? Leads to what? Can you provide an example? I cant imaging that If I just start shorting full battery power to every lead in the car I wont blow or burn out something
UMDJesse is offline
clutch problem ? Master / Slave Cylinder Problem rthompson48082 YJ Wrangler Technical Forum 34 11-30-2011 06:31 PM
Belt problem, blinker problem, and a random problem... Mike89db TJ Wrangler Technical Forum 10 12-14-2009 06:34 AM
brake pad problem, and front drive shaft problem bluejeep2088 TJ Wrangler Technical Forum 1 05-12-2008 10:34 AM
Brake Fluid problem or Jeep Drinking problem daledaniel TJ Wrangler Technical Forum 6 01-04-2008 10:11 PM
FINALLY! fixed idle problem and stalling problem Big-n-Broke-YJ YJ Wrangler Technical Forum 4 02-28-2006 08:50 PM
