EGR tube block-off solution for the 4.2L - JeepForum.com
post #1 of 10 Old 09-02-2011, 07:57 PM Thread Starter
tslroper
There are alot of threads asking how to block off the hole in the exhaust manifold if you remove the EGR tube. Solutions were pretty hard to come by aside from welding it shut. I thought i would share my findings to make it easier for anyone else facing this canundrum.
The oil drain plug for late model dodge trucks fit perfectly. Autozone carried it for $4.99. The box says its M22x1.5 size and uses the end of a 3/8" drive ratchet to tighten it. I put a little threadlocker on the threads then spread exhaust putty around the outside to make sure it doesnt work loose. So far (its been a week) absolutely no problems with it.
I hope this saves someone else the headache of trying to find something to fit.
tslroper is offline
post #2 of 10 Old 09-02-2011, 08:20 PM
davsyjdd
Thanks tslroper, I can use that tidbit of info.
davsyjdd is offline
post #3 of 10 Old 09-03-2011, 10:25 PM
headhunter47
Did this tonight but ran out of light before I could put the intake back together. Thanks for the idea!!
headhunter47 is offline
post #4 of 10 Old 09-03-2011, 11:24 PM
Sawicki4wd
Any idea what year dodge it comes from. I made a plate out of 3/8 Aluminum and it 100% blew apart in less then a week. So this would be an amazing fix. I tried everything from a plate to brazing to that exhaust putty
Sawicki4wd is offline
post #5 of 10 Old 09-04-2011, 07:18 AM
jay-h
Not sure why you would remove the EGR. It does not hurt performance and actually serves to cool combustion temperature.
jay-h is offline
post #6 of 10 Old 09-04-2011, 10:57 AM Thread Starter
tslroper
There are no years listed on the packaging, it simply said dodge trucks. It was something carried on the shelf at the local autozone though. Should be easy to find, just compare the size. Like i said, it listed it as M22x1.5
tslroper is offline
post #7 of 10 Old 09-04-2011, 11:12 AM
mcmud
1983 CJ8
While I totally agree with jay, I thank you for posting this info, it should be a help to those that are in search of this fix.
mcmud is offline
post #8 of 10 Old 09-04-2011, 05:32 PM
Sawicki4wd
I removed mine because I couldn't get a replacement egr tube
post #9 of 10 Old 09-04-2011, 07:20 PM
Tompatt
1987 YJ Wrangler
same. i had to cut the tube when I changed out intake manifolds and just had to weld the ends shut.
Thomas
-1987 YJ
Tompatt is offline
post #10 of 10 Old 09-04-2011, 10:48 PM
Sawicki4wd
It's a hard thing to come by. I looked everywhere. Mine has no emissions in mass so as longs as the egr is there it doesn't matter. It's annoying tho. The exhaust manifold I bought new stripped my 02 sensor. So I had to bolt that up to. I could have gotten a new one but I wasnt gonna pull it back off.
Tube dangling from my engine block (PHOTOS) ggking7 TJ Wrangler Technical Forum 34 12-20-2010 07:01 PM
Flushing/draining the BLOCK without removing block drain...cause its stuck HowUDerin TJ Wrangler Technical Forum 10 08-05-2010 06:57 PM
Engine block heater as a solution??? hart4jeeps TJ Wrangler Technical Forum 4 09-29-2009 07:30 AM
TnT Tube fender, air box solution Schwalby TJ Wrangler Technical Forum 1 12-29-2008 12:12 PM
My solution to side marker lights with tube fenders WMiller13 YJ Wrangler Technical Forum 8 03-08-2008 11:55 AM
