ECU problems AGAIN (crash course in brain surgery) - JeepForum.com
post #1 of 14 Old 02-02-2008, 11:53 AM Thread Starter
AhmedTheCamel
alright so a little while ago I replaced my capacitors on the ECU and everything has been running smoothly then all of a sudden ive been having to put a blow dryer on the ECU before I will get the check engine light, due to the fact its been about -7 around here, I was wondering the reason I just breifly read abuot the trick to get it started but I never understood what it does.
AhmedTheCamel is offline
post #2 of 14 Old 02-02-2008, 12:43 PM
sasquachYJ
try redoing the capacitors
sasquachYJ is offline
post #3 of 14 Old 02-02-2008, 06:31 PM
NewdRiver_
....why are you messing around inside the ECU
Go down to I-55 Auto Salvage and have them get you one.
They ordered a new one from Texas for me for (get ready)......$400
Hey maybe us three could get together sometime to wheel?
NewdRiver_ is offline
post #4 of 14 Old 02-02-2008, 07:57 PM
Berb_15
because electricity and circuits are awesome
Are they ceramic or electrolytic caps?(ive never pulled my jeep's ecu apart but im assuming electrolytic) did you get the polarities correct?? that can make a big difference in any circuit(with electrolytic anyways...)... and what made you switch them out to begin with?
And I'd price around for an ecu, I got one off of ebay from a salvage yard for 175 when i did my 4.0 swap, if you do have to purchase one...
"Lock tite!!
Mans best friend cuz your dog won't keep your jeep from falling apart."
Berb_15 is offline
post #5 of 14 Old 02-02-2008, 10:42 PM
cruz 45
cruz 45's Avatar
If your interested in a used ecu I have my used one that I can part with ?
1993 2.5 mpi
cruz 45 is offline
post #6 of 14 Old 02-03-2008, 12:31 PM Thread Starter
AhmedTheCamel
thakns for the response
first off i would love to meet up sometime and go wheelin, but yeah on the rebuild i did check the polarities my step brother helped me do it and he is a computer wiz i actually did a write up on this topic but it has backfired on me, but i cant figure it out i know its the capacitors but like im just not sure whats causing these problems besides the cold
post #7 of 14 Old 02-04-2008, 12:05 PM
HalfShaft
double check the solder joints on the caps. A bad solder job will possibly cause issues as the ecu, and the case and the board, and the components, and all the other things involved shrink at different rates due to the temp.
Double check for a grey color at the joints they should also be smooth and have flowed onto the board. If they are lumpy and/or shiny redo them they are probabally no good.
Also, check to make sure none of the traces around the caps were damaged during the replacement. A small scratch in a trace may seperate when it gets cold.
As for why anyone would change the caps themself, I fixed my ecu with bad caps for 4 bucks. If anyone would like I will change theirs for 175.00 and even throw in free shipping. I used the 171.00 leftover to buy my wife a present so that I can spend more on the toys.
Its always a good idea not to bite the hand that can make your life miserable.
Hope to help had the same issue now it is fixed.
"Quitters only get stuck in the same place once"
1993 Grand Cherokee Limited - "Rose"
1994 Wrangler - "White Whale"
2000 Ford F250 Diesel - "Bigfoot"
2000 Ford Excursion V10 - "Hungry"
HalfShaft is offline
post #8 of 14 Old 02-04-2008, 01:36 PM
Berb_15
Shiny joints are actually what you want, and just to back my statement up look at any circuit board like a computer for example.
"Lock tite!!
Berb_15 is offline
post #9 of 14 Old 02-04-2008, 03:37 PM
HalfShaft
Berb 15 is correct and I am not.
Sorry, my fingers were a typin and my brain was a little behind. Shiny - good, grey - bad
I will now do my pennance, 10 hail marys or is that 10 bloody marys?
post #10 of 14 Old 02-04-2008, 09:24 PM
Berb_15
for such a big mistake I think it needs to be upped to 15 bloody marys...
To the OP, do have the link for the writeup you did?
"Lock tite!!
Berb_15 is offline
post #11 of 14 Old 02-05-2008, 02:30 PM
HalfShaft
I believe I will drink to that.
Halfshaft
post #12 of 14 Old 02-06-2008, 01:49 PM
papa_panda
I would check how well they were re-insulated after being soldered on. If moisture managed to get trapped in and short the circuit I could see how you'd have problems.... Hope this helps...
'92 White YJ w/Grey soft top, 2.5L from '97 TJ, original 5-Speed, Silver Grizzly Alloy rims from 2001 TJ with Goodyear Wrangler GS-A 225/75R15
Marine Corps Jeep Club Member #7
White Jeep Club Member #350
papa_panda is offline
post #13 of 14 Old 07-31-2010, 04:28 PM
jaketolsen
well i did the same thing replaced the capacitors and it fired right up but its summer time now so hopefully when it gets cold mine dont start having problems i live in northern wisconsin so it gets really cold
jaketolsen is offline
post #14 of 14 Old 08-01-2010, 07:52 PM
bob082484
I had the same problem and thought I messed up my capacitors. Turned out that it was the intake air temp sensor. Hope that helps.
bob082484 is offline
Crash Course In Brain Surgery Replacing Capacitors On ECU sasquachYJ YJ Wrangler Technical Forum 298 05-30-2017 07:46 PM
Back surgery Axl Jack Wrangler General Discussion 19 05-15-2009 08:35 PM
Problems to look for after a crash mjkolb02tj TJ Wrangler Technical Forum 14 12-08-2007 10:11 PM
YJ in surgery now.... BigMac869 YJ Wrangler Technical Forum 4 02-06-2007 01:21 PM
Jeep is in Surgery 1BadJeepX06 TJ Wrangler Technical Forum 3 01-29-2007 10:47 AM
