ECU pin output parameters NEEDED! - JeepForum.com
post #1 of 3 Old 04-08-2010, 12:03 PM Thread Starter
lexinator02
I am trying to see if the new computer I bought is screwy or I have sensors acting up so I am looking for what all the pins on the ECU measure with a multimeter.
I literally wanna know what each pin is supposed to measure in volts so I can just run out each pin and see what is normal and if any arent, then I can troublshoot accordingly..
I would love it if someone could either take 5 minutes and quick measure it at key on and IDLE.
Or if someone knows what each pin should readout that would work as well.
I have a 90 TBI so it has to be TBI.
Thanks
Dave
Low Output 4 Cylinder Jeep Club Member # 187
1995 YJ
lexinator02 is offline
post #2 of 3 Old 04-08-2010, 01:18 PM
Que89YJ
I can do a scan for you tomorrow. I dont have one available for mine here at work. I posted to you on the last one that you were probably dealing with blown sensors because the regulation on the sense lines were knocked when the controller fried without the links. Use a meter and check your Throttle posion sensor IAC and temp sensor. Here is a link that should help you out. Sensors, Systems, Solenoids, and Such on Chrysler cars
Que89YJ is offline
post #3 of 3 Old 04-08-2010, 02:05 PM Thread Starter
lexinator02
Hey I appreciate all the info you've helped me out with these past few weeks. Its helped me a ton!
Dave
1995 YJ
AX5 Output Shaft Help Needed Zazoos YJ Wrangler Technical Forum 4 01-23-2010 10:23 PM
Rear output seal for SYE same as front output seal? Imped TJ Wrangler Technical Forum 0 10-23-2009 09:57 AM
how do you know if engine is 2.5 high output or low output? yjwrangler YJ Wrangler Technical Forum 16 08-27-2009 01:56 PM
high output or low output j85rule YJ Wrangler Technical Forum 9 09-21-2006 09:56 PM
Enhanced Parameters for Chrysler ICEAKACRAZYDOG TJ Wrangler Technical Forum 0 12-25-2004 07:30 PM
