ecu mounting - JeepForum.com
post #1 of 3 Old 09-27-2010, 02:30 PM Thread Starter
steveluddy
ecu mounting
pulled a 2.5 from a 95 wrangler 6 mnths. ago and cant recall where the ecu was when i pulled the motor and all of its wiring. mounting it in an 88 wrangler that had a 4.2, im thinking it was on the firewall below the fuse block but there doesnt seem like there will be enough room once the charcoal can, goes in. thanks for any help in advance.
steveluddy is offline
post #2 of 3 Old 09-27-2010, 02:33 PM
idaholtby
The ecm mounts to the firewall, driver's side, below the brake booster and clutch master.
idaholtby is offline
post #3 of 3 Old 09-27-2010, 02:44 PM Thread Starter
steveluddy
thanks for the reply. i knew i wasnt to far off.
Gas Can Mounting Oman Jeep TJ Wrangler Technical Forum 34 08-21-2010 06:11 AM
mounting cb help jeeper92 TJ Wrangler Technical Forum 4 02-25-2010 10:23 PM
Do I need a mounting kit on my 93 yj ALPHA-1 YJ Wrangler Technical Forum 7 02-19-2010 02:21 PM
mounting a CB stephen YJ Wrangler Technical Forum 8 07-10-2003 09:08 AM
GPS mounting mpadfield TJ Wrangler Technical Forum 0 03-01-2003 11:56 AM
