ECM swap? - JeepForum.com
post #1 of 7 Old 02-27-2011, 07:02 PM Thread Starter
g4x4xgeoff
ECM swap?
last step of my tf-999 to ax-15 swap, the ECM needs some attention.
I either need to trick it into thinking the automatic is still there, or replace it with a manual ECM.
what would you do? Keep the current ECM, and trick it (and how), or swap out a manual ECM (will it just snap into the harness?)
Originally Posted by Hurley91 View Post
I could be drunk, high, raped and almost dead.... and I could still recognize it.
g4x4xgeoff is offline
post #2 of 7 Old 02-28-2011, 06:36 AM
Que89YJ
Keep it and just ground the nuetral saftey switch. Its the same controller.
Que89YJ is offline
post #3 of 7 Old 02-28-2011, 11:54 AM Thread Starter
g4x4xgeoff
Easy enough, are there any other concerns you can see, orhappen to know which wires off hand?
post #4 of 7 Old 02-28-2011, 12:18 PM
Que89YJ
Wire from Pin 30 of the ECU:
Que89YJ is offline
post #5 of 7 Old 02-28-2011, 05:16 PM
Mark05059
I was looking for this yesterday
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #6 of 7 Old 03-01-2011, 09:41 AM
Que89YJ
Cut the wire from pin 30 near the ECU and run it to a good chasis ground near the ECU.
The spedo input is necessary for the ECU to function properly and for speed to work on the cluster. Here are 2 links for info:
http://www.jeepforum.com/forum/f12/4...ection-963222/
http://www.jeepforum.com/forum/f12/h...73/index2.html
The crank sensor should be located here:
http://www.jeepforum.com/forum/f12/r...o-fire-650259/
Im not sure what you got the AX 15 out of but the flywheel and the Crank sensor are very important. The fly wheel is like a tone wheel for the crank sensor. Every rotation send a specific sequence of pulses though the crank sensor to the ECU. The fly wheel must be from a 91-95 YJ or an equivelent XJ with the same engine. It will not start if it isnt! Also the location of the crank sensor is critical in setting the timing. It should be located here:
http://www.jeepforum.com/forum/f12/4...x-15-a-928285/
Post back here to your thread if you have any more questions. I hope it helped.
Que89YJ is offline
post #7 of 7 Old 03-01-2011, 12:55 PM Thread Starter
g4x4xgeoff
Thanks man,
flywheel came out of a 94 4.0 so we're good on that aspect, got the cps ready to go in,
hopefully all goes well tonight!
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
body swap VS motor swap questions baltimorebiker YJ Wrangler Technical Forum 9 03-29-2010 09:49 PM
Gathering parts for Axle swap, SOA, and V8 swap... tank29 YJ Wrangler Technical Forum 7 12-03-2009 02:42 AM
Dana 30 diff. swap vs. gear swap BBCAT YJ Wrangler Technical Forum 2 02-28-2009 01:17 PM
HVAC Control Swap: Swap just the lower ac/heater housing, or all of it? Justin Brimm TJ Wrangler Technical Forum 5 12-20-2007 03:29 AM
