ECM Removal??? - Page 2 - JeepForum.com
post #16 of 26 Old 02-22-2014, 11:04 AM Thread Starter
dennisonwj
Okay, I think I am sold on the HEI system. Many have said DUI over CRT and vice versa. Could anyone please elaborate on why DUI over CRT considering it is over 120$ more per distributor?
dennisonwj is offline
post #17 of 26 Old 02-22-2014, 11:08 AM Thread Starter
dennisonwj
I am sold on the HEI after your comments and research, thanks for all the inputs. Here are some questions.
1) Many say DUI, but CRT has seemingly the same performance parts for 100$ cheaper. Opinions please?
2) I know the plug wires need to be swapped for HEI wires.
3) Can I run the stock plugs, or do I need something else?
4) What vacuum hoses and electrical wires can I remove after it is installed?
post #18 of 26 Old 02-22-2014, 02:14 PM
jay-h
DUI is an HEI (GM High Energy Ignition) distributor. They provide the physical system as well, available calibrated for non ECM and reputed to be better than the Chinese knockoffs.
Here is a comparison of a DUI vs original GM HEI on a Chevy
http://www.chevyhardcore.com/tech-st...butor-install/
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #19 of 26 Old 02-22-2014, 11:17 PM Thread Starter
dennisonwj
After research, I am with you om the HEI. Several members have mentioned that the CRT HEI distributors (http://www.crtperformance.com/html/jeep_hei_s.html) are at least comparable to the DUI line (http://performancedistributors.com/p...i-distributor/). Thy are both HEI, but the CRT is MUCH less expensive. DUI vs. CRT?
post #20 of 26 Old 02-23-2014, 04:57 AM
roadyrob
1987 YJ Wrangler
I haven't run a DUI distributor so I can't really say first hand if its much better than the CRT. from researching both there are some differences. DUI runs their own custom module with longer dwell time, CRT runs a stock G.M. module, you can buy the dui module from summit for 50.00. the vacuum advance is non adjustable on the DUI, you give them your motor specs and they set it for you. the CRT is adjustable and should work ok out of the box but needs to be adjusted for peak performance. they both claim a 50.000 volt coil. both appear to be well built and should work fine for many years, I and others have run the CRT dizzy for over 5 years with 0 problems.
personally I'm happy with my CRT distributor but I'll probably buy the DUI module just to have it on hand when mine finally goes bad.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #21 of 26 Old 02-23-2014, 05:11 AM
Tarpo
Originally Posted by jbolty
It is a CRT. Works great, really woke up the engine. No problems after about 5 years. I have not personally ever talked to anyone who ever had an issue with hardened gears. Other than guys claiming they know a guy whose friend had a bad experience I think it's a non issue. Pretty much all the wires can go away and 90% of the hoses.
My 88 4.2 had the cam shaft gear stripped by the CRT hardened gear. It took years to happen, but it left me stranded.... When I did an engine swap I used the same CRT, I just used the pulled the hardened gear off and used a NoN hardened gear from a factory distributor (modified it in the lathe to fit the CRT)
88 yj. 95 4.0 4 Brl carb, Msd ignition, offenhouser intake, headers. Ford 8.8 rear end, sun fire seats. About to install a newer ax 15 to replace my tired ba10.
Tarpo is offline
post #22 of 26 Old 04-12-2014, 07:56 AM
Dwarf
1987 YJ Wrangler
Is it possible to just buy a DUI without hardened gears? I concede hardened gears may not hurt the cam gears, but why risk it.
Dwarf is offline
post #23 of 26 Old 04-12-2014, 08:15 AM
Dwarf
1987 YJ Wrangler
To answer my own q, on summits site - it drops all amc dizzying if you select iron gears
Dwarf is offline
post #24 of 26 Old 12-03-2016, 08:39 AM
CarolinaDave
I've installed the MSD 6A ignition, MSD coil and distributor. The nutter bypass was previously done before. I removed the old ignition unit and cut mucho wires going back it the ECM. Over by the battery there is 2 relay by pass and flat 1" wide x 2" long diode box of some kind. Ive disconnect some wires left others in tack. My 89 YJ has and 85 of older 258 motor with a weber carb. Timing is correct, but will not start. Figured something to with the wires. What over problems did you run into removing wires and what in the diode box too? Any help would appreciated.
CarolinaDave is offline
post #25 of 26 Old 12-03-2016, 01:50 PM
timatoe
timatoe's Avatar
Those relays are for the sol vac system and the manifold heater, I'm not sure what diode box you're referring to. The only thing over by the battery that I would say you need is the relay for the manifold heater.
Are you sure you're not 180* out on the distributor?
FYI, thanks for using the search function etc, but a new thread would likely get you better responses because some won't read the entire thread and answer only the first post without seeing it's several years old. So if you're not getting responses try a new thread.
timatoe is offline
post #26 of 26 Old 12-04-2016, 06:54 PM
CarolinaDave
Thanks, I'll re-post this. I maybe on the time, not sure. Is firing where the timing light is marking the correct time. Would it do that if it were 180 out?
