Ebrake stays engaged - JeepForum.com
post #1 of 13 Old 03-04-2013, 09:39 PM Thread Starter
bigbossd1030
Hey guys, this morning I was on my way to work and as I pulled the ebrake the light stayed on and the pedal only came up about half way. It has done something similar before on cold mornings but never this. When I went to pull forward I had very little power, I could tell the brakes were dragging bad. So I put it in 4wd and it was back to normal at the end of the parking lot. I just want to know what I need to replace to make it work properly again. Recall has been done and I have replaced all brake components except for the ebrake cables and the brake lines. Thanks for any help
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #2 of 13 Old 03-04-2013, 10:17 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Could you pull the pedal the rest of the way up by hand?
Luck Favours The Prepared
Anticanman is offline
post #3 of 13 Old 03-04-2013, 10:20 PM Thread Starter
bigbossd1030
I could but it would just drop down again, about half way. When I pulled it up by hand, well foot, the light would come off. So I thought I would hold the release handle and pump it to see if it would help, but it did not. I could push it to the floor, almost, then it would have tension on the return, but again only to about half way. It also did the same thing after work, but this time it did not grab at all, the pedal just stayed down a bit, enough to keep the light on.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #4 of 13 Old 03-04-2013, 10:25 PM
gunshw301
Might be water in the lines freezing? Air in lines or a leak. The valve will sense a leak and the light will stay on.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #5 of 13 Old 03-04-2013, 10:27 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I would get under the jeep and tap the connection between the cable and the brake mechanism itself. Its the only connection to the springs with the wheels on. Might be time for a brake upgrade.
post #6 of 13 Old 03-04-2013, 10:28 PM Thread Starter
bigbossd1030
I thought that these were just cable driven systems for the ebrakes? I could be wrong. With water in the lines, I feel that I would have more symptoms than this, such as spongy or saggy pedal. And just poor braking power period.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #7 of 13 Old 03-04-2013, 10:30 PM Thread Starter
bigbossd1030
So you are thinking it may be crud and corrosion etc in the outer casing of the brake cables?
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #8 of 13 Old 03-04-2013, 10:33 PM
JeepinJeremy
you have 3 E-brake cables that connect as one unit. loosen the adjuster and remove all 3 from the connector. pull each one by hand until you find which cable is binding up and replace it or just replace all 3. cheap easy repair. I doubt it's your rear brake shoes unless you put them on backwards and there dragging.
JeepinJeremy is offline
post #9 of 13 Old 03-04-2013, 10:35 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Getting underneath and finding the source is step 1. I usually just start prodding until I find it.
post #10 of 13 Old 03-04-2013, 10:36 PM Thread Starter
bigbossd1030
I put them on the way they came off so I will assume they are right. And I would loosen the adjuster, but I tried this once, it wasn't going to turn. Heat and pb blaster. I am still looking for a new one. But I will try and do this.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #11 of 13 Old 03-05-2013, 07:52 AM
Flajeeper1
1987 YJ Wrangler
Buy a new connector plate and then check everything out. You may be able to check the cables while they're still connected but I couldn't. I had a bad cable locking up.
Flajeeper1 is offline
post #12 of 13 Old 03-05-2013, 10:29 AM Thread Starter
bigbossd1030
Yup both cables are locking up. I removed the equalizer so hopefully they free up, I'm going to have a set made here at work. Thanks for the help guys!
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #13 of 13 Old 03-10-2013, 04:42 PM Thread Starter
bigbossd1030
Got it all fixed up. New lines and I cleaned up the equalizer to look new. Problem solved.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
