Ebay HEI? - Page 2 - JeepForum.com
post #16 of 21 Old 04-18-2010, 05:20 AM
dodger889
The only reason points are causing you problems is the simply fact. You need to adjust the dwell properly. It's not adjusting the gap but the fine tuning. You can help them with a msd box to get a better spark. The only reason most went with electronic ignitions where to get away from point bounce on high revving engines. Besides that you can usually fix a set of points with just a piece of emery cloth or file to get you off the trail or back home. They are a little more maintenance. But if you replace them once or twice a year they will run forever.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #17 of 21 Old 04-18-2010, 11:30 AM
Alabamaranger
Originally Posted by Dado8788 View Post
Why? Well, I'm looking for a "drop in" solution. The GM HEI setup looks to be the simplest way to upgrade the ignition.
One more question; how much of an improvement can I expect to see over the old points and condenser setup that's on it now? Will I notice it while driving?
You have points in there now? If so, must be a CJ engine or setup.
90 YJ, 4.2 with 2150 carb 4.0 Head and headers, Nutter with TFI and MSD. 1" BL, 2.5" spring lift, 33", Goodrich KM Mud Tires. Dana 30 w Aussie, Ford 8.8 w LS. 9000lb HF Winch.
Alabamaranger is offline
post #18 of 21 Old 04-18-2010, 01:11 PM Thread Starter
Dado99TJ
Junior Member
Dado99TJ's Avatar
The points aren't giving me a problem; they actually work quite well. That's why I wondered if I'd even see a difference by going to a different setup. I thought if I could do it inexpensively I'd give it a shot.
No, AFAIK, its the original engine. The PO had trouble with the ICM and replaced the whole setup with a dizzy for an old CJ engine. Really, the only problem I have with it is that the tach isn't hooked up.
Nightcrew member #331
Blue Jeep Club member #332
Dado99TJ is offline
post #19 of 21 Old 04-18-2010, 02:45 PM
dodger889
Oh the tach is an easy fix. That is attached to the coil anyway and is connected to the same side has the dizzy wire giong to the tach You should find a dark green wire in the wiring harness coming from the firewall connector. If not you can run one from the coil to the back of the tach.
post #20 of 21 Old 04-18-2010, 03:57 PM
Alabamaranger
If the PO gutted all of the wiring and DS box. I would go with the HEI system. Much better that the points.
If the wiring is still there, do the nutter and use the stock DS box with the TFI conversion..
post #21 of 21 Old 04-18-2010, 07:52 PM
Dislsmoke
I didn't see anyone mention DUI ignition systems. They make a quality unit. I'm running one in my AMC360 works really good and a good quality. They are a little more but it is worth it.
85' CJ-7, 258, T-5, D-300. Soon to be 360, t-18,d-20
4" skyjacker, 33's, frame up resto, Custom built everything else.
Custom Dashs built to your specs
website.
Dislsmoke is offline
Which Ebay H4 HID Kit? superslayer TJ Wrangler Technical Forum 18 11-24-2009 08:58 AM
Ebay SYE Mayfair_Jeeper TJ Wrangler Technical Forum 4 12-19-2008 06:45 PM
89 YJ from Ebay Beachdrvr YJ Wrangler Technical Forum 2 07-05-2008 06:28 AM
HEI on Ebay? BennyLT YJ Wrangler Technical Forum 6 02-12-2008 01:17 PM
Did anyone see this guy on eBay?? paultyler YJ Wrangler Technical Forum 9 10-22-2006 11:48 AM
