Ebay Electric Fans - JeepForum.com
post #1 of 11 Old 03-30-2010, 07:42 PM Thread Starter
tc90xj
1994 XJ Cherokee
Ebay Electric Fans
Found what looks to be like a nice aftermarket setup for electric fans for my 91 YJ.
Heres the ebay link:
PROCOMP DUAL 8" INCH ELECTRIC FAN & THERMOSTAT KIT 39 : eBay Motors (item 330416912658 end time Apr-22-10 05:27:57 PDT)
I have two important questions:
1. First off, is 1000 cfm as stated going to be plenty enough pull to cool off my engine reasonably?
2. I have a OE setting thermostat (Believe it to be 195 degrees opening). The wiring kit included with this fan setup is set to kick in at 180 degrees and shuts off 10 degrees later at 170. Is this going to co-incide nicely with my setup. (for example, letting my engine reach the proper temp without the fan running all the time)
FYI... I plan on making a pipe fitting that splices into the upper radiator hose that I can thread the water sensor into. I dont feel comfortable drilling and tapping my block.
Let me know what you think. Any advice is appreciated and much welcomed.
tc90xj is offline
post #2 of 11 Old 03-31-2010, 09:57 PM Thread Starter
tc90xj
1994 XJ Cherokee
Bump...
Nobody at all?
tc90xj is offline
post #3 of 11 Old 03-31-2010, 10:37 PM
YJMonster
have you looked at flex-a-lite i think its the same price and they have one designed for the jeep i think.
2000 xj 4.5 Rubicon Express extreme duty(sold)
1988 yj 2.5 RC lift, 1/2 boom shackles- My baby
YJMonster is offline
post #4 of 11 Old 03-31-2010, 10:54 PM
YJake
I would just use a Taurus fan my friend. I did and couldn't be happier.
To tell you the truth, I don't use the fan 90% of the time. It's just not needed. I run a 195 degree thermostat and while moving my YJ never gets above 160 degrees. The only time that I use the fan is while off road because I'm crawling at low speeds thus causing heat to build up, especially during the summers here in Florida. It is also nice to be able to turn the fan on and off with the flick of a switch, VERY nice for when you cross deep waters.
Keep in mind I said switch, and that's all that I have it wired to basically. I wired it into the fuel pump line so that it can't be left on when the key is in the "OFF" position, other than that it's just wired to a toggle switch in the cab, no thermostat regulating it at all. It's wired to the fuel pump so that I don't murder my battery by forgetting to turn the fan off
The Taurus fan is a beast even on it's low setting. I never even wired up the "High" setting. It has never been needed. Even on low it will make my temp needle drop like a limp ****.
It's perfect for when you need to cross water like this.
And look at all this space it gives us with the 2.5L ! I can stand on the front axle when I work on the engine now! (Also not how perfect it fits over our radiators. I bent some galvanized sheet metal 90degrees and used a few self tapping sheet metal screws to hold it to the radiator, been holding strong for 9 months now!)
The fan had cost me $30 at the junkyard and I spent maybe another $15 on a relay, wiring, and fuse.
I'm not trying to convince you to go the Taurus route, I just wanted to share my good experiences with it.
Good luck!
Jake
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline
post #5 of 11 Old 04-01-2010, 04:49 AM
littlejohn411
Thats a great deal for that setup in my opinion,I have a new derale adjustable controller and new taurus fan ready to go in and paid about $150 for the setup.
It also looks like an easy install with those zip fasteners and comes with the better temp. sensor,not that crappy probe that you stick in your rad.....
After reading the listing better I see those fans are rated at 1000 cfm "total" both fans,I thought it was 1000 each,I'm not sure thats enough. I know the taurus fan has an insane amount of cfm.
I'm sure someone will chime in with better knowledge about what's required for your engine.
GOT GUNS?
littlejohn411 is offline
post #6 of 11 Old 04-01-2010, 08:25 AM
MWguy101
Hey guys I am a little confused on the whole electric fan issues. Is that better then a stock fan? Is a taurus fan from a ford taurus or is that the brand name? What CFM should I get for a 4 banger? Are they a pain to wire up?
95 YJ, 4" RC lift, 33x12.50x15 Durtrac
MWguy101 is offline
post #7 of 11 Old 04-01-2010, 08:55 AM
YJake
-Better than stock pending on the fan, and you engine doesn't have to turn a fan while idling.
-The Taurus fan is from a 3.8L Ford Taurus, years 1990-1995. It's a 3 wire fan. (Two speeds one ground)
-The Taurus fan is used on some 1/4 mile cars to cool down between runs, and those are big block V8s. It is way more than enough for the 2.5L or even the hot tempered 4.0L on low setting.
-The fan is advertised as having 2500 CFM on low speed and 4500 CFM on high. This baby sucks in small animals and children on high!
Hope that clears stuff up!
Jake
/l , [____],
()_) ()_)==@=)_)
YJake is offline
post #8 of 11 Old 04-01-2010, 06:40 PM
littlejohn411
I think the CFM will be an issue with that setup after reading into it.
Here's the taurus fan..
1995 95 Ford Taurus Radiator Fan Assembly NEW : eBay Motors (item 110513745839 end time Apr-02-10 08:56:41 PDT)
And a good adjustable fan controller...
DERALE ADJUSTABLE ELECTRIC FAN THERMOSTAT SWITCH RELAY : eBay Motors (item 290416998535 end time Apr-21-10 10:46:41 PDT)
The fan is very easy to install,take a look at the pic in Yjakes post,very little modding is needed and the instructions for the fan relay are pretty good.
GOT GUNS?
post #9 of 11 Old 04-01-2010, 08:54 PM Thread Starter
tc90xj
1994 XJ Cherokee
Looks like I'll be going to my local junkyard tomorrow and trying to find a 3.8taurus fan. And a vendor in town that has a good adjustable fan controller kit. I dont want to wait on shipping if I already have the fan.
tc90xj is offline
post #10 of 11 Old 04-17-2010, 02:11 PM
MWguy101
Hey guys I was at the upull lot today and could not find a 3.8L v6 fan. But what I was able to find was a 3.0L V6 fan. It only has 2 wires coming off the fan, not 3. Do you think that will work as well as a 3.8L or did I just waste my money?
MWguy101 is offline
post #11 of 11 Old 04-17-2010, 02:24 PM
MWguy101
They did have a 3.8L V6 dual fan from a 95 ford van, i think it was a windstar. Should I have gotten that one instead?
MWguy101 is offline
Best way to Reduce Fan Noise? (standard & HD clutch fans, blades, electric fans) jtice TJ Wrangler Technical Forum 11 10-01-2009 06:39 AM
2 electric fans. bmxrules39 TJ Wrangler Technical Forum 2 10-29-2008 08:07 PM
Those of you with electric fans... HVACman TJ Wrangler Technical Forum 0 09-26-2005 11:37 PM
Electric fans HeavyAssault TJ Wrangler Technical Forum 2 09-25-2005 07:50 PM
well i got my electric fans in yeep YJ Wrangler Technical Forum 4 04-18-2003 10:54 AM
