Quantcast Which is easier? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Which is easier?
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 03-01-2009, 06:56 AM   #1
shinerm02
Which is easier?
I have two sets of axles for my yj. The one set is complete just bolt it on and I would be ready to drive. But...it has 3.07 gears. The other set needs seals, vacuum motor, axle ujoints, dust shields, ball joints and I would have to take the steering linkage from the first axle too. This axle has 3.54 gears. So theses are the gears I want for how I am going to drive, mainly on the road.
So which is easier....fix all the crap wrong on the axle with the gears I want or swap out the ring and pinion gears into the axle that is ready to go?
shinerm02 is offline   Reply With Quote
Old 03-01-2009, 07:02 AM   #2
jodylikeamelody
fix the other ones if you are not experienced in changing gears.
jodylikeamelody is offline   Reply With Quote
Old 03-01-2009, 07:21 AM   #3
alc60560
Fix em It's alot cheaper than regearing
alc60560 is offline   Reply With Quote
Glock Forum
