e350 Master cilender with 8.8 disk rear - JeepForum.com
post #1 of 7 Old 07-11-2010, 06:37 PM Thread Starter
Chaos_Theory_Z
I recently did a E350 mc swap (yesterday) and i read all these threads about people locking up their 35s with all disks with little effort and i cant even get my 33 to lock when i stomp on it, what am I missing ? im using the stock prop valve and bleed the whole system.
Chaos_Theory_Z is offline
post #2 of 7 Old 07-11-2010, 07:26 PM
mario figueroa
I did the same swap,and my brakes improve just a litle bit,not good enough so I decided to go with the 95 Boster and M/C what a diference,i did this just yesterday.
mario figueroa is offline
post #3 of 7 Old 07-11-2010, 08:21 PM Thread Starter
Chaos_Theory_Z
i just took a liittle more air out of the system and now i can get the rear to lock, ya mario that will probably be my next step , thanks the for the input
post #4 of 7 Old 07-11-2010, 08:34 PM
hesserdude07
i have a stock brake set up other than extended braided lines with a 8.8 rear and can lock up all four tires!
1993 Silver YJ. SBC 300hp. 700r4. NP231 hybrid. 35" Mud Terrains. 7" Toyota Basterd packs. 8.8 Welded. D30 loc-rite. 1" body lift. 4" LED tails. Custom bumpers. Warn M8000. Hella's. (Trail rig)
hesserdude07 is offline
post #5 of 7 Old 07-12-2010, 12:32 PM Thread Starter
Chaos_Theory_Z
ya hesserdude i have herd that from a couple people. do you mean you lock them up on the street or on the trail ?
post #6 of 7 Old 07-12-2010, 04:23 PM
hesserdude07
i can do both. if i slam the pedal at a red light while already going pretty slow, it will lock them up and squeal the tires. And it does help with trail riden, for Hard corners and such...
post #7 of 7 Old 07-12-2010, 08:09 PM
OneCleanYj
Although I'm not running an 8.8 I've got rear disks on my 9" and I LOVE them. I still want to add the 95 MC and new prop valve but that will come in due time. I've always felt that they should have a bit more braking power though so yesterday I bled all four corners once more and it made a HUGE difference! I slammed the pedal down pretty hard at 60 MPH yesterday and I easily could have locked up the rears
92 YJ. Lifted, rubbered, geared, and more
OneCleanYj is offline
E350 master cylinder in a yj? Tulsachokehold YJ Wrangler Technical Forum 26 07-31-2015 12:31 PM
Clutch disk or master cylinder or flywheel? mystangt TJ Wrangler Technical Forum 9 05-25-2010 02:41 PM
What rear disk brakes to use on Rear D44 with 5 on 5.5"? jeepteejay TJ Wrangler Technical Forum 4 07-31-2008 11:49 AM
An 87 E350 MC Ok? bamato YJ Wrangler Technical Forum 1 11-08-2007 09:20 AM
C6 brakes, rear disk conversion, and a new Master Cylinder Grewe02 TJ Wrangler Technical Forum 8 08-29-2007 01:31 PM
