E-fan wirng question - JeepForum.com
post #1 of 10 Old 02-23-2010, 10:03 PM Thread Starter
czjeeper
I've been running a Taurus electric fan for about a year now.
I love it.
I just have it wired right now to come on with the key.
I only have the low side wired, and it does a more than adequate job of cooling.
I would like to modify my wiring to include a temp sensor (which I have from Autozone), and to automatically come on with the A/C.
I don't need or want a switch in the cab.
I don't care about the high side fan. I've never needed it.
Not sure if it should also come on when my York OBA is on. I don't think it needs to.
Can anybody help me out with a simple wiring diagram to make this all work?
I've looked and can't seem to find a diagram that does what I've described.
Thanks!
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #2 of 10 Old 02-23-2010, 11:31 PM Thread Starter
czjeeper
I thought I would add that I'm using the Tyco 75 amp relay.
I screwed around for a little while in the garage but can't figure it out.
Hope somebody can help.
US Army combat vet
czjeeper is offline
post #3 of 10 Old 02-23-2010, 11:50 PM
jbolty
jbolty's Avatar
what controller/sensor do you have?
most 12v relays have the same plug pattern
pin 30 is power from the battery
pin 87 is the fan power or other load
pin 85 is ground
pin 86 is power from the switch to control the relay
you just need power from the battery to the relay, then use the sensor to turn the relay on and off.
jbolty is offline
post #4 of 10 Old 02-24-2010, 12:02 AM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
You can use this diagram and just take out the switch and the high side relay. And the LED relay too if you want. Just run 12v hot into #30 on the low side relay, and 12v from the ignition switch to #85.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #5 of 10 Old 02-24-2010, 12:11 AM Thread Starter
czjeeper
pin 85 is ground
I'm using the adjustable temp controller from Autozone.
Also, how do I turn the fan on when I turn on my a/c?
US Army combat vet
czjeeper is offline
post #6 of 10 Old 02-24-2010, 07:26 AM
jbolty
jbolty's Avatar
IIRC the control circuit for the existing system energizes the high idle solenoid with an orange wire. Find that and use it to control the relay.
jbolty is offline
post #7 of 10 Old 02-24-2010, 08:51 AM Thread Starter
czjeeper
So, can I use the thermostat and the A/C wire both plugged in to 85?
US Army combat vet
czjeeper is offline
post #8 of 10 Old 02-24-2010, 09:29 AM
jbolty
jbolty's Avatar
That should work. One or the other or both will energize the relay.
Actually, thinking about it as I'm typing that might not work because the high idle would then come on whenever the temp sensor side has power, unless you put a diode in the circuit.
I would probalby wire a seperate circuit and use the A/C to kick on the high speed side.
jbolty is offline
post #9 of 10 Old 02-24-2010, 09:37 AM Thread Starter
czjeeper
So, I found a few diagrams after searching all night on the web.
On the second diagram, can I just delete the switch?
US Army combat vet
czjeeper is offline
post #10 of 10 Old 02-24-2010, 10:01 AM
jbolty
jbolty's Avatar
That would work but personally I would keep the switch. It's nice to be able to turn off the fan for either working on something or driving thru water.
jbolty is offline
Lift/Tires question and Cleaning soft top & engine question Bryan_16 TJ Wrangler Technical Forum 16 05-19-2012 03:25 PM
Front sway bar question + bonus disco question WranglerTom TJ Wrangler Technical Forum 7 12-02-2011 08:13 AM
1988 carberator question and wiring (general) question prljeep YJ Wrangler Technical Forum 15 05-08-2009 11:50 AM
quick connecting rod question and tourqe wrench question???? johnrezz YJ Wrangler Technical Forum 2 10-18-2008 07:20 PM
Tire question(noob question but just a quick answer needed) 07SilverX JK Wrangler Technical Forum 3 12-25-2007 03:35 PM
