e-fan hookup question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > e-fan hookup question
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread Yesterday, 09:22 PM   #1
silleYJ
I am hooking up a electric fan on my 88YJ 2.5L DD. Is there a hot wire under the hood anywhere that is only hot while my key is on? Or am I going to have to drill and run through the firewall? If I have to drill though my firewall I may just hook up a manual switch just in case I ever do go through deep water.
1988 YJ Wrangler 2.5L for fun
2014 WK Grand Cherokee for dependability
silleYJ is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 09:38 PM   #2
jbolty
jbolty's Avatar
most e fans draw a fair amount of power so you will almost certainly need a relay, heavier wire, some sort of switch and normally a temp sensor so it only comes on when needed.
Are you having cooling problems now?
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote Quick reply to this message
Unread Today, 12:40 AM   #3
Drednot
Drednot's Avatar
What jbolty said...
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35
12 Cherokee 4x4,3.7L,
"Non Vi Sed, Arte"
Drednot is online now   Reply With Quote Quick reply to this message
Unread Today, 01:07 AM   #4
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
I don't know the differences between a '88, and a '94. But on mine, I'm pretty sure that there is in the PCM. Its been about 10 years since I installed mine. Here's a schematic that might help you with the wiring:
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
My Jeep
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
www.rubiconramblers.com
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is online now   Reply With Quote Quick reply to this message
