#1 | |
E-brake adjust
O.K., I did a search but the only info I could find was on a TJ. My e-brake won't hold the heep on anything but level and so I'm thinking I need to replace or adjust it but the instructions I found for the TJ detail taking the rear drum apart and checking a bunch of stuff. Do I really have to do that or can I just tighten the cable some?
I've never performed this, do I need special tools or just the usual?Thanks for the help
[]|||||||[] Colorado Jeep Club Member # 176 \m/(..)\m/ "Rock on!" |
#2 |
Uncle Paul has spoken...
You just need to tighten the cable. The adjustment is on the driver's side just forward of the rear wheel...sort of under the driver's door. You will see a square metal plate with a nut/bolt you can tighten to tension the cable.
The best picture I could find is this: http://www.commtechreview.net/jeep/images/tuffycsc8.jpg It is the same adjustment plate I was referring to but it is obviously on a different Jeep, not a YJ. But you'll get the idea.
My Jeep - Video My Jeep in the Snow 92 YJ, 35' MTR Kevlars, Klune/Dana 20, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers, JK electric swaybar, T&T tube fenders, custom cv driveshafts, RE 4.5 XD springs, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s, AtoZ Rockers, Skid-Row Engine skid plate, Teraflex Bellyup, JCR Offroad 1 Ton TieRod, rock lights, RE hand throttle, M.O.R.E. roll cage, corners, 9000lb winch with synthetic cable in-cab winch controller (12voltguy.com), Dual Blue Top Optimas with 12voltguy dual battery controller, a/c (ackits.com) |
#3 |
Thanks for the quick resonse!
#4 |
ISO 9001 Compliant
Just to add to that. You should make sure that the star wheel adjustment inside the drum is correct first. Then adjust the e-brake.
#5 |
O.K. That'll probably be something I'll just dig into and see if I can figure it out. I'll be doing a lot of different work on it tomorrow, clutch master replacement, oil change, etc. I'll pull the rear wheel and look at the brakes. This jeep is missing a wheel stud on one of the axles and another is stripped. Those are pretty easy to replace aren't they?
#6 |
E-brake recall
ok here it is. Jeep/Chrysler is doing a emergency brake recall on alot of jeeps. mine did the same thing that you described on your jeep. if you take your jeep to the dealer they will do a vin number search to tell you if your vehicle is a candidate for the repair...no charge for you
jason |
#7 |
ISO 9001 Compliant
recall info here
http://www-odi.nhtsa.dot.gov/cars/problems/recalls/recallsearch.cfm http://www.jeep.com/webselfservice/jeep/index.jsp?screenName=recall&country=us&emailUrl=go ToEmailForm%28%27R%27%29 Just bang out the stud and put in a new one. Pull it into place with a lug nut but make sure to use a few oversize washers so you don't bottom out the nut on the bolt flange. Otherwise it wil not seat all the way. It will make sense when you see it. brake shoes are cheap. good time to renew everything. |
#8 | |
Jello Puddin'
Yeh, check the recall out first, mine was the same way before they fixed it.
#9 |
YEAH!! The PO of my jeep didn't do the recall so I can get it fixed. Now I just have to make sure the stealership doesn't rip me off. It also says I need to have the fuel pump gasket replaced, what's that about?
#10 | |
Got my eye on you.....
Stealership CANNOT RIP YOU OFF. They have to do the work BY FEDERAL LAW!!!!!! Even if you were the 500th owner. Call ahead though and make shure they have the parts and make an apptment.
http://i131.photobucket.com/albums/p...k_banner-1.gif Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
