dumb noob question - JeepForum.com
post #1 of 4 Old 09-14-2011, 05:29 PM Thread Starter
Scoooter6175
dumb noob question
Just bought a 95 yj with a 4 inch suspention lift and 33's , The rear axle shock mount is worn out, I was looking at the warrior lift spring skid plates, that have a built in shock mount. http://www.quadratec.com/products/16038_02.htm. is this a good option or not, can't find any reviews. any thoughts?
Scoooter6175 is offline
post #2 of 4 Old 09-14-2011, 05:48 PM
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
You said rear shock mount, the link up there is for the front, and they are incorrect, the screw in mount is for swaybar end links...
Personally I would not waste a nickel on warrior products...
Mark
Smoke em if you got em!
Mobile_Homie is offline
post #3 of 4 Old 09-14-2011, 06:00 PM
zeus87gn
1987 YJ Wrangler
Dumb answer for noob - fix the shock mount
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
post #4 of 4 Old 09-14-2011, 06:18 PM Thread Starter
Scoooter6175
just click on it from the forum hyper link leads to the Warrior Products Rear U-Bolt Skid Plates, Leaf spring U-Bolt Skid Plates have a screw-in shock stud on the plate
Off the install instruction = Install your WARRIOR skid plates making sure that the studs can be installed to accommodate your sway bar or shock absorber
dumb question creedua YJ Wrangler Technical Forum 3 08-04-2011 07:17 PM
Tire question(noob question but just a quick answer needed) 07SilverX JK Wrangler Technical Forum 3 12-25-2007 03:35 PM
Dumb Question Truggy TJ Wrangler Technical Forum 8 11-08-2007 03:29 PM
Dumb, dumb question about mounting front license plate on stock bumper flagstaffjeeper TJ Wrangler Technical Forum 18 08-03-2006 08:05 AM
Dumb Question etwolfe7 TJ Wrangler Technical Forum 14 01-07-2005 11:09 PM
