Dumb lug nut question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Dumb lug nut question
Rough Country Lift Kits and Parts!Bds fox ipf 2.0 racing series shocks now available at rock20 Ton Press Brake DIY Builder Kit @ Swag Off Road
Unread 08-18-2012, 07:07 AM   #1
weerwolv
weerwolv's Avatar
Hi all,
Just picked up Black Rock 15" Aluminum wheels and planned on getting McGard lug nuts to replace the garbage on there now.
Question:
McGard makes two styles
1.) 3/4 Bulge style Acorn Lug Nut
2.) 13/16 Regular style Acorn Lug Nut
Which one should I get and is one better or not for aluminum wheels?
weerwolv is offline   Reply With Quote
Unread 08-18-2012, 10:03 AM   #2
Anticanman
Luck Favors the Prepared
Anticanman's Avatar
They both work the same, it's a matter of preference. I have both on mine because I stripped all my nuts on one wheel because of a bad stud. I prefer the 3/4 because the 13/16 is a little tight against my center caps.
Anticanman is offline   Reply With Quote
Unread 08-18-2012, 10:32 AM   #3
phunhawg98
Junior Member
phunhawg98's Avatar
he stripped his nuts....
bahaaaaaaa
phunhawg98 is offline   Reply With Quote
Unread 08-18-2012, 10:47 AM   #4
evanjeep
Hahaha
evanjeep is offline   Reply With Quote
Unread 08-19-2012, 05:24 AM   #5
weerwolv
weerwolv's Avatar
Thanks Anticanman as always..
Just ordered the McGard Black 3/4 Bulge Acorns
Unread 08-19-2012, 12:10 PM   #6
JWELK
I thought they were 19mm?
JWELK is offline   Reply With Quote
Unread 08-19-2012, 12:18 PM   #7
Mean Max
Don't poke the bear
Mean Max's Avatar
3/4" = 19MM
More or less.
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Unread 08-19-2012, 12:21 PM   #8
Anticanman
Anticanman's Avatar
19mm? Oh hell no! It's 3/4", Jack!
Unread 08-19-2012, 12:22 PM   #9
Mean Max
Don't poke the bear
Mean Max's Avatar
Tastes great! Less filling!
Max
Unread 08-19-2012, 12:28 PM   #10
evanjeep
I thought 18mm =3/4
Unread 08-19-2012, 12:33 PM   #11
Mean Max
Don't poke the bear
Mean Max's Avatar
Originally Posted by evanjeep
I thought 18mm =3/4
Nope.
Max
Unread 08-19-2012, 03:20 PM   #12
Opihi59
from here it gets rough
Opihi59's Avatar
18mm = 0.7086 or 23/32" more or less
19mm = 0.748 which is almost 0.75 which is 3/4"
and check the metric quote in my sig line......
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock http://kamfamily.wordpress.com/2009/...waiian-limpet/
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline   Reply With Quote
Unread 08-19-2012, 08:45 PM   #13
evanjeep
Gotcha
Unread 08-19-2012, 09:09 PM   #14
Opihi59
Opihi59's Avatar
Another real close one is 13mm which is just about 33/64 or 0.512 which is close enough to 1/2." I pretty much use the 13 mm and the 19 mm as interchangeable between 1/2 and 3/4 especially in a 6 point socket.
Isn't this a fun place????
Unread 08-19-2012, 09:31 PM   #15
evanjeep
Isnt there one mm they dont make i think its 15
