duel steering stabilizers, who makes the best? - JeepForum.com
post #1 of 6 Old 04-23-2001, 10:26 PM Thread Starter
renegade0351
is anybody putting out duel steering stabilizers for jeeps beside trailmaster. i dont care too much for the way they have theyre system together, a peice of angle iron bolted to the frame seems kinda shabby. whos running duels and what kind?
thanks.
89 sahara, 4.2 , k551 weber, nutter bypass, tuffy stereo security console & under seat security drawer, 4'pro comp & 3'body, front waggy44 w/detroit & 4.88, rear waggy44 w/detroit & 4.88, teralow sye, tw's cv drive shaft {rear}, warn locking hubs, boomerrangs all around, 35x15.50 tsl-sx swampers { love that roar}.
renegade0351 is offline
post #2 of 6 Old 04-23-2001, 11:45 PM
osburn
osburn's Avatar
What on earth makes you think you need a dual stabilizer? I'd fix whatever the real problem is if you think you need duals on a Jeep.
Matt Osburn
Score 1032
osburn is offline
post #3 of 6 Old 04-24-2001, 02:43 AM
jeffy
jeffy's Avatar
You should be able to drive fine without a steering stabalizer if everything is fine. The stabalizer only dampens the shock from bumps. There should be no reason to have more then one. I've seen up to 4 but that truck had 5 or 6 shocks for each corner not including kicker shocks.
*** www.4BangerJP.com ***
jeffy is offline
post #4 of 6 Old 04-24-2001, 11:24 PM Thread Starter
renegade0351
what size & brand tire are ya'll running ?
35x15.50 super swampers here.
post #5 of 6 Old 04-25-2001, 03:51 AM
jeffy
jeffy's Avatar
Me? 35x12.5 MTR's. I think Matt is running 35x12.5 SSR's.
jeffy is offline
post #6 of 6 Old 04-25-2001, 02:48 PM
rayray
rayray's Avatar
A single stabilizer should be more than enough. Everyone I've wheeled with that has had two, ended up removing one (kept getting destroyed on rocks) or drilling one out because they liked the way it looks with two.
Earth First! We can wheel the other planets later
rayray
rayray is offline
What exactly do steering stabilizers do? TJShadow TJ Wrangler Technical Forum 17 02-28-2013 06:55 PM
Steering stabilizers jbrug141 TJ Wrangler Technical Forum 20 06-21-2007 11:36 PM
Do I Really Need Steering Stabilizers???? diveguy TJ Wrangler Technical Forum 5 11-24-2004 08:35 AM
Steering stabilizers FootballStud 63 YJ Wrangler Technical Forum 4 11-14-2004 01:21 AM
Steering Stabilizers steveskody TJ Wrangler Technical Forum 3 08-14-2002 10:41 PM
