Dual alt kits, anyone? - JeepForum.com
post #1 of 7 Old 07-12-2013, 09:42 PM Thread Starter
Jakes93yj
Hi guys, I need some help findnig a dual alt setup. i have my stock alt the a 117/136 amp alt off a Cherokee and a dual alt kit will be cheaper the a 220+ amp alt. Reason I want it is cause soon I will be running about 2 or 3 batterys, for my Sound system(I have INSANE voltage drop) and auxiliary lights( 2 100 watt KC lights) and possibly a winch soon. so anyone know where i can get a dual alt setup and a belt for it?
Thanks
-Jake
Jakes93yj is offline
post #2 of 7 Old 07-12-2013, 09:58 PM
sprngrider
You will have to make one, but why bother? Get a 160a from a durango, 2 die hard platinums, and wire lights up like you are clark griswold
1994 2.5L WRANGLER S.
sprngrider is offline
post #3 of 7 Old 07-13-2013, 08:27 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I suggest a dual battery system using some deep cycle batteries and try the GC alternator. If you have bad voltage drop, you'll want to look into a 1 farad cap wired inline to the amps to replace that drop you're experiencing. There's no way you'll need two alternators. I've dabbled in car audio in the past, what kind of system are we talking about?
Luck Favours The Prepared
Anticanman is offline
post #4 of 7 Old 07-13-2013, 10:52 AM
pete1991YJ
If you have insane voltage drop then you have too much I2R losses and resistance... you need *much* bigger cables, try welding cable. Should be less than a quarter ohm per foot in the larger sizes.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #5 of 7 Old 07-13-2013, 12:49 PM
pasinbuy
Think of another way as suggested. You alternator is a very large drain on Horsepower to your vehicle. Look at the inside of a exercise bike. They have a alternator to make resistance for the rider. Big drain on your motors power..
pasinbuy is offline
post #6 of 7 Old 07-13-2013, 03:22 PM
pete1991YJ
Actually no. The alt doesn't pull any more than a few HP, it isn't physically possible. Simple math: 1 HP = 746 watts. This equals 62 amps at 12 volts. 186 amps = 3 HP at the crankshaft. You will *need* at least 2/0 welding cable all around in order to actually get that much power out of a 186 amp alt. Like I said, check your cable size first and how good are your connections. Before you spend big money, get your total resistance as low as humanly possible.
BTW this applies even more for guys with winches.
post #7 of 7 Old 07-15-2013, 07:54 PM
pasinbuy
Pete, if your figures are right and I have no reason to doubt them. In my opinion that is a lot of HP.
If you can hear your motor slow a bit due to alternator draw which we all have to me that is a lot.
pasinbuy is offline
