drvr front brake line issue - JeepForum.com
post #1 of 2 Old 04-13-2010, 02:21 PM Thread Starter
Peltboy25
I just noticed that the driver side front tire rubs the soft portion of the brake line when the wheel is turned to the right. Visually, the line is in the same position as the passenger side. Why is only one side rubbing? How do I adjust this? Obviously I need to replace the worn line, but I don't see any obvious misalignment of the brake line. Wussup?
Drive like you're going somewhere.
Peltboy25 is offline
post #2 of 2 Old 04-13-2010, 03:01 PM
Louie4
Since you have 31" tires I'm assuming 10.5" or 12.5" wide. I ran 31 x 10.5" tires with stock TJ wheels and it rubbed mine quite a bit. I finally zip-tied them out of the way. When I finally got new ones I used a spring attached to the frame.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
front brake line issue mmarmouz TJ Wrangler Technical Forum 19 10-14-2009 08:43 AM
Front Brake Line HELP!!!! dh4011 JK Wrangler Technical Forum 2 08-25-2007 03:57 PM
Front brake line size-Hard line?? learfxr YJ Wrangler Technical Forum 4 07-14-2007 07:24 PM
Front Brake line RE 2.5 murray249 YJ Wrangler Technical Forum 1 07-13-2004 07:54 PM
Front Brake Line Limits? EricS TJ Wrangler Technical Forum 1 08-11-2003 11:51 AM
