Drum Brake Issue - JeepForum.com
post #1 of 4 Old 10-18-2013, 01:23 PM Thread Starter
vmann7
1987 YJ Wrangler
Drum Brake Issue
Hey all, long story short I was bleeding my brake system and ran into an issue with the rear bleeder valves, just too many years on the road, so I just changed the entire cylinder out. I've taken pics and have only done one side so far and the putting together went fine till I installed the adjuster cable. Its hooked on as you can see but there is no tension at all, any ideas?
vmann7 is offline
post #2 of 4 Old 10-18-2013, 01:31 PM
jbolty
jbolty's Avatar
from the picture it looks like the adjuster is turned all the way in. I bet it's ok once the shoes are adjusted for the drum. Also, bang on the shoes a little with a rubber hammer. Not too hard, but sometimes they get hung up or off center.
jbolty is offline
post #3 of 4 Old 10-18-2013, 01:33 PM Thread Starter
vmann7
1987 YJ Wrangler
Hmm, that does make sense let me give it a shot, I'll let you know. Thanks.
Nope, the adjuster actually made it worse. I did figure it out though. The cable guide has a protrusion on the rear that's designed to fit in the hole on the shoe, I didn't make sure it was properly adjusted when I attached the spring, resulting in the slack.
vmann7 is offline
post #4 of 4 Old 10-19-2013, 09:08 AM
Mark05059
looks like you may have the wrong cable... do you have 9 or 10 inch brakes (measure the inside of the drum). Im betting you have 9 inch and they gave you items for 10" drums....
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
