Drum brake dissapointment. Help - JeepForum.com
post #1 of 23 Old 04-14-2011, 10:27 AM Thread Starter
ayerightaye
put another d35 under my heap
with
3k miles on brakes
9" drums
all springs look good
plenty of pad,
drums and look great
bled, re-bled, bled again, no bubbles
no leaks
still up on stands and can not stop wheels!
adjusted as usual
MC changed last year.
Ideas and techniques please!
KING OF THE DRIVEWAY
YJ '89 4.2 UNDER constant CONSTRUCTION
"But I thought you fixed it last week!!"
ayerightaye is offline
post #2 of 23 Old 04-14-2011, 11:35 AM
Provojeep
Have you checked to be sure your wheel cylinders are not frozen? If they got water in them they could be rusted. That would be my best guess if you can't stop the wheels with it on stands.
93 YJ, 4.0L, AX15 with 90 frame. D44/9" on 35" MTR's.
Provojeep is offline
post #3 of 23 Old 04-14-2011, 11:40 AM
pasinbuy
Alright, maybe a crazy question but with this problem it almost always turns out to be the front calipers.
Look at your front calipers bleed fittings. Is the bleed fitting on to of the caliper or on the bottom of the front calipers? Look at both.
If one or both is on the bottom then you have to turn it around off of the rotor to bring the bleeder to the top. Then rebleed your system.
pasinbuy is offline
post #4 of 23 Old 04-14-2011, 12:09 PM
MJMPC
Did you adjust the rear brales before bleeding?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #5 of 23 Old 04-14-2011, 01:52 PM Thread Starter
ayerightaye
Cylinder and rest of internals look great, no rust.
Front brakes are correct and were not touched. Only swapped rear. (but will check when home)
Brakes were adjusted after bleeding.
Thanks guys, keep this thinkpot stirring
post #6 of 23 Old 04-14-2011, 06:18 PM
skreed
Collapsed rubber brake hose in rear? You will not see it, it will be the inner lining.
Kink or obstruction in metal line?
You sure everything is together correct?
skreed is offline
post #7 of 23 Old 04-14-2011, 07:46 PM
MJMPC
Did you bleed all 4 corners?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #8 of 23 Old 04-14-2011, 08:09 PM
Nibbley15
Does your "brake" light work, the one in the dash, if so is it on? This is a far stretch from the other posts, but is it possibly the proportioning valve?
Nibbley15 is offline
post #9 of 23 Old 04-15-2011, 08:31 AM Thread Starter
ayerightaye
Only bled the back, again
calipers strong
was able to stop wheels on stands for a few seconds, then they would start again
Hoses are braided SS and 2 years old
Hard lines are smooth
brake light works but is not on
Guess its off to the junkyard for disc parts.
post #10 of 23 Old 04-15-2011, 10:22 AM
4.7stroker
Do you have a firm pedal or is it spongy?
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #11 of 23 Old 04-15-2011, 11:59 AM
kahanabob
if you are getting a good stream when bleeding the rear then all seems well up to that point leads to the wheel cylinders???
kahanabob is offline
post #12 of 23 Old 04-15-2011, 01:00 PM
superj
i went through this on my cherokee after i replaced everything, including the master cylinder. it turned out to be the rod from the booster to the master was not adjusted properly so not enough pressure was going to the cylinders to stop the wheels. brakes felt good and everything was replaced but no stopping on stands. my neighbor, a n old old retired mechanic, came over and listened to everything pushed the peddle with his hand and told me to adjust the rod. after that, everything worked perfectly. there is an adjustment nut on the end of the rod to adjust for new MCs since htey don;t always fit exactly the same.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #13 of 23 Old 04-15-2011, 03:32 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
You should mechanically adjust brakes before bleeding. Or you could push the wheel cylinder pistons right out of the wheel cylinder bodies since there is no upper brake contact because the brake adjuster allows the brakes to be completely collapsed.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #14 of 23 Old 04-15-2011, 03:43 PM
LordEnki
2006 WK
Unfortunately, the adjuster does not keep the pistons in the wheel cylinders. The shoes do. Don't press the brakes with the drum off. Wheel cylinders are on top and adjuster is on bottom.
LordEnki is offline
post #15 of 23 Old 04-15-2011, 06:58 PM
dodger889
Is this with new drums and shoes?
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
Rear Drum Brake Help - Tight Drum AFTER new shoes! rastadog TJ Wrangler Technical Forum 31 10-21-2011 06:19 PM
Drum brake or disc brake? BeepTheJeep Wrangler General Discussion 3 06-11-2010 02:00 PM
2001 TJ Drum brake to Disk brake questions javelin390 TJ Wrangler Technical Forum 0 03-16-2010 06:42 PM
Dana 44?? Regarding Disc Brake To Drum Brake samsammy23 TJ Wrangler Technical Forum 6 03-28-2004 09:44 AM
Drum brake help? ColoradoSkier TJ Wrangler Technical Forum 1 08-08-2003 01:19 PM
