Drum Brake Adjustment Problems? - JeepForum.com
post #1 of 4 Old 03-21-2010, 09:55 PM Thread Starter
Ferenckzy
Here's the deal:
Replacing drum brakes... new shoes, drums, hardware, cylinder... yeah. We just got one side done when it got dark out, but the other side has plenty of pad life left until Thursday when I can get it done.
Anyways, the drum was a little hard to get on, and we can't figure out why. Everything was re-installed EXACTLY the way it came out, it looks exactly like the other side... I'm lost.
The star adjuster is all the way in, I let the emergency brake have some slack, bled the system multiple times, topped off the fluid, but still, I'm getting the soft pedal, the dash light's on, and the braking power isn't what it normally is, even though the shoes are dragging against the drums a little bit. I even tried that retarded "slam the brakes in reverse" method and they made a popping sound when I went forward again.
Did I miss something??????
Just give us some quarters so we can get drunk.
'94 WhyJ, Tall, Locked, RCV'd
Ferenckzy is offline
post #2 of 4 Old 03-21-2010, 10:20 PM
Straycur
Originally Posted by Ferenckzy View Post
Here's the deal:
How long has the light been on? You're talking about the brake light, right? If you had a leak, your proportioning valve may have closed off your rear brakes. Have you bled all the brake lines? You need to start at the farthest away and bleed each one seperately.
If you have done this and can get a decent pedal, you can stand on the pedal with both feet until you hear a "pop", that's what it takes to reset your proportioning valve. Pics may help.
Straycur is offline
post #3 of 4 Old 03-21-2010, 10:48 PM
MJMPC
Did you bleed all your wheels or just the one where you replaced the cylinder?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #4 of 4 Old 03-22-2010, 03:58 PM Thread Starter
Ferenckzy
Oops, I caught my problem... I just got back from work, pulled the drum and, big surprise, a couple springs and the star adjuster fell out. I forgot to tighten the emergency brake cable when I put the new one on. This caused the part of the line inside the drum to push the star adjuster out of whack and hell broke loose. Tightened the cable, reinstalled everything, works perfectly now.
This brings up another question... should there be that much cable in the drum where it would cause another mess if the emergency brake cable became loose while driving, or would the star adjuster be tight enough against the shoes when it self-adjusts to keep everything together?
Brake Drum Adjustment hole Cover alexr40 TJ Wrangler Technical Forum 4 02-15-2010 02:39 PM
Brake Drum problems Cchandler TJ Wrangler Technical Forum 6 01-17-2010 05:19 PM
Drum brake adjustment Brew461 TJ Wrangler Technical Forum 11 10-27-2009 03:15 PM
Drum Brake Adjustment Problems mkuzmukerau TJ Wrangler Technical Forum 11 06-01-2005 10:07 PM
drum brake problems dreblow YJ Wrangler Technical Forum 3 04-10-2005 05:33 PM
