Dropping the fuel tank..... - Page 2 - JeepForum.com
post #16 of 20 Old 06-26-2013, 01:35 PM
pasinbuy
If you have the plastic tank. The hoses to the tank are a dealer only part. One end of the hose is molded. Do not use a regular hose and force it on.
You will need a new tank gasket too.
Please fill in your profile, I am not sure of what year you are working with.
pasinbuy is offline
post #17 of 20 Old 06-26-2013, 01:45 PM
CrawlingForward
Yes and no. There are different ID on the ends, but with some overlap and hose clamps, it's fine (2 years later or so, for me).
http://www.jeepforum.com/forum/f12/w...oline-1138853/
http://www.jeepforum.com/forum/f12/h...emoval-981049/
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #18 of 20 Old 06-26-2013, 02:45 PM
tom_sprecher
In addition to all the good suggestions above, when I dropped mine the sender was not working properly so I used a pencil eraser to burnish the sector. After that the resistance was linear as I swept the float through its range.
Tom
tom_sprecher is offline
post #19 of 20 Old 06-26-2013, 10:10 PM
Nazzo
I replaced all my hoses with standard fuel line hose.....I have had no problems
Don't be a slappy...you slacker
Nazzo is offline
post #20 of 20 Old 06-27-2013, 09:36 AM
GrantYJ
Originally Posted by chuck172 View Post
Access door worked for me.
X2... or X3 ...well however many other people said...
There isn't much left of my Jeep that I haven't "adjusted" in some way, but the access hatch to the fuel pump is one of my favorites. It just sits there, doesn't really do anything, but when something fuel related goes wrong, it's a Godsend.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” ― Robert M. Pirsig, Zen And The Art Of Motorcycle Maintenance: An Inquiry Into Values
GrantYJ is offline
