Dropping the fuel tank..... - JeepForum.com
post #1 of 20 Old 06-25-2013, 04:17 PM Thread Starter
yjgirl88
We are dropping the fuel tank to put in a new fuel pump and fuel pressure regulator. Any other projects we should undertake as long as the tank is dropped?
yjgirl88 is offline
post #2 of 20 Old 06-25-2013, 04:22 PM
UZI4U
Get new hose to replace the old stuff. MAybe a few hose clamps in case one breaks. Of course, a new fuel filter too.
MCLMM
UZI4U is offline
post #3 of 20 Old 06-25-2013, 04:23 PM
jserna
1987 YJ Wrangler
This would be a great time to install an after market bumper if you do not have one. Or install some brackets on the inside of the rear cross member to strength it.
jserna is offline
post #4 of 20 Old 06-25-2013, 04:35 PM Thread Starter
yjgirl88
Yep, got the fuel filter too. What about the float? Is that an easy replacement?
yjgirl88 is offline
post #5 of 20 Old 06-25-2013, 04:46 PM
CrawlingForward
x2 on hoses.
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #6 of 20 Old 06-25-2013, 04:51 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Can you say.. 20 Gal Mod?
EDIT: Fill In your Vehicle Information in your Jeep Forum Profile so we can better assist you.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 33" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #7 of 20 Old 06-25-2013, 04:53 PM
gunshw301
Get a new fuel sending unit seal. They are cheap and its a good time to change it.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #8 of 20 Old 06-25-2013, 05:17 PM
StanF
+ for the 20gal mod
+ for all new hoses
Frame to Shackle Bushings...unless you cut the bolt, it's difficult or impossible to get that bolt out past the gas tank.
StanF is offline
post #9 of 20 Old 06-25-2013, 05:28 PM
Louie4
If you see a square plastic container (in the tank) that the fuel pump sits into you may want to rip it out. I say this because they will warp and bow in causing your float to hang up and only read 1/4 or 1/2 tank.
I did that 7 or 8 years ago with no issues and it fixed my stuck gas gauge.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #10 of 20 Old 06-25-2013, 06:03 PM
sprngrider
I will second this suggestion. This seal is a major leaker if it is factory, I think they had a recall on this part. Mine was crumbling apart.
1994 2.5L WRANGLER S.
sprngrider is offline
post #11 of 20 Old 06-25-2013, 06:06 PM
chuck172
Access door worked for me.
chuck172 is offline
post #12 of 20 Old 06-25-2013, 09:28 PM
mudsweatNgearz
1987 YJ Wrangler
Replace rollover valve grommets. They get old and brittle and can leak.
I wondered why the baseball kept getting bigger and bigger....then it hit me!
mudsweatNgearz is offline
post #13 of 20 Old 06-26-2013, 06:12 AM
NHfireLJ
NHfireLJ's Avatar
Originally Posted by chuck172 View Post
access door worked for me.
this^^^
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #14 of 20 Old 06-26-2013, 07:59 AM
bogleparsons
I also made an access plate, may never need to drop tank again!
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #15 of 20 Old 06-26-2013, 10:50 AM
tdewit
Check and replace the wiring harness plug. They tend to corrode and make your Jeep stop / sputter.
tdewit is offline
