drop pitman arm help for d60 on yj - JeepForum.com
post #1 of 8 Old 02-21-2014, 06:20 PM Thread Starter
richh789
1987 YJ Wrangler
I changed my front springs on my jeep. I noticed two issues
1 when turning hard the drag link hits the bottom of spring. Only hits a little, would like to do hi steer, but bj 60 hi steer requires machining, and seems a little sketchy to have such a large amount leverage on just a few bolts. Will a weld hold up on knuckle??
2 steering does not go from lock to lock, which means to me that my pitman arm is too short.
if I change pitman, I could get one with more drop and solve both issues. If you measure from parallel to parallel surface were it mount to box to the drag link I have 4 out to out. Anyone know of an arm that is longer than yj arm that I could get with another inch of drop??
Anyone have bj 60 hi steer experience??
richh789 is offline
post #2 of 8 Old 02-22-2014, 01:51 AM
fratis
fratis's Avatar
This is one of the problems with a 60 swap. The pitmans are much shorter then the usual 60 arm of around 9." I made my own pitman, actually im on mrk3, as it was the best way to match the length of the histeer arm.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #3 of 8 Old 02-22-2014, 11:59 AM
Norcal_chris
Norcal_chris's Avatar
A superlift 1104 is 7in on center and 3in drop. Its what I use.
The machines bj 60 knuckles hold up jujust fine. Check out fourwheelsupply.net he machines and sells the arms for a good price
Ruined a perfectly good jeep.
OCT '13 & OCT '14 YJOTM 2014 YJOTY
Norcal_chris is offline
post #4 of 8 Old 02-22-2014, 01:38 PM
jsawduste
2006 YJ Wrangler
Is Tony`s Twisted Arm a consideration ? I really don`t know a lot about it but figured I`d throw it out there.
In the Savvy LJ thread John made up his own PiT-A that had some unique features.
jsawduste is offline
post #5 of 8 Old 02-23-2014, 06:12 AM Thread Starter
richh789
1987 YJ Wrangler
I've searched Tony's twisted arm with no luck
richh789 is offline
post #6 of 8 Old 02-23-2014, 10:30 AM
jsawduste
2006 YJ Wrangler
http://www.genright.com/ProductInfo....2#.UwohpcAo7X4
Not sure it applies to your situation but was throwing it out there for consideration.
post #7 of 8 Old 02-24-2014, 12:13 AM
fratis
fratis's Avatar
The problem with the genright and others are they are too short. You want the arm to be of similar length to the histeer arm specifically from TRE to balljoint.
fratis is offline
post #8 of 8 Old 02-24-2014, 08:46 AM Thread Starter
richh789
1987 YJ Wrangler
^^^yep. I'm thinking wj drop arm. I need 6.25 long and 5" overall drop. (Yj stock is 2" drop)
richh789 is offline
