Drop pitman arm? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Drop pitman arm?
Ruffstuff Axle Simple Swap Kit!ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread Yesterday, 10:31 PM   #1
3MJeep
Drop pitman arm?
I'm not sure where I should post this but I have a YJ with 5 inch suspension lift and 35s. The steering is all over the place. I can hold the steering wheel strait but it will still dart all over the road. all ball joints and TREs are new. From the looks of the pitman arm i think I need a drop pitman arm. Do you guys suggest this or do you have any other ideas?
3MJeep is offline   Reply With Quote Quick reply to this message
Unread Today, 07:36 AM   #2
1320yj
You need the drop pitman arm , install it and have the front end aligned by a competent shop. Be sure and note the caster angle if it is out of spec add angled shims under the spring perches to correct the caster angle.
1995 2.5 5Speed SOA 33x12.50 Mud Rovers
1320yj is offline   Reply With Quote Quick reply to this message
Unread Today, 08:34 AM   #3
JeeperDon
Patience, Grasshopper
JeeperDon's Avatar
The goal is to get the drag link parallel to the axle, which takes more than a pitman arm to accomplish with that lift height.
'93 YJ, '02 GM 4.3 Vortec V6, SOA, dual ARB's, 8.8+D30(w/WarnHubs), 4.88 gears, 35" BFG KM2's, AX15, 15x7 wheels, NP231+4:1+SYE+2LO, York OBA, Warn M8000, no top or doors Apr-Oct.
Member and Web guy: New Mexico 4 Wheelers My Truck Page on NM4W Site
JeeperDon is offline   Reply With Quote Quick reply to this message
Unread Today, 12:57 PM   #4
1tonmut
1tonmut's Avatar
1983 CJ7
SOUNDS LIKE IT DRIVES PERFECT ! ....just kidding .
5 inch springs ? no angle shims ? sounds like you just recently lifted it.
The darting all over the road you describe sounds more like the caster is out of wack than a pitman arm issue , get the alignment angles checked and shim as needed .
With 5 inches lift leaf springs I would ditch the track bar [not necessary with leaf springs] and install a drop pitman arm and maybe do a tie rod end flip to the top of the knuckles to level the drag link more [and lift the tie rod up a couple inches] otherwise you are going to have bump steer issues.
Edit: If you keep the track bar it should be parallel with the drag link to prevent bump steer, so if you install a drop pitman you will probably also have to drop the track bar frame mounting point and maybe raise the track bar axle mounting point in order to get them parallel as possible to minimize any bump steer [toss the track bar].
1tonmut is offline   Reply With Quote Quick reply to this message
Unread Today, 05:18 PM   #5
zillla
1975 CJ5
What he said
Pull my finger
zillla is offline   Reply With Quote Quick reply to this message
Unread Today, 05:43 PM   #6
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Moved to the YJ Technical forum.
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
TJ
HOLIDAY THEMED GIVEAWAY!
Jerry Bransford is online now   Reply With Quote Quick reply to this message
Unread Today, 05:52 PM   #7
Reno72
Reno72's Avatar
Yes you should have a drop pitman arm, but with your lift I'd be looking at over the knuckle or high steer. I have the same size lift and went to Ruff Stuff Chevy 1 ton Y link and flipped the tie rod over the knuckle. Much better manners on road and off. If you're interested I have a new RE drop pitman I'm selling 1/2 price of new.
"Says the guy driving the plastic Barbie Jeep". JLH
I have nothing against a Prius, I just wish the drivers would peddle faster.
Reno72 is offline   Reply With Quote Quick reply to this message
