Drivetrain Swap - JeepForum.com
post #1 of 9 Old 03-11-2012, 06:19 PM Thread Starter
YJ43
Drivetrain Swap
Hello,
I'm in the process of setting in the engine/trans/transfer case to find the exact location to weld the motor mounts (going from I-4 to I-6). I have an AW-4 and 231 TC and one thing that I noticed when setting everything in is that the drive shaft does not appear to line up exactly with the output of the TC. Is this a problem? Rear axle is a Ford 8.8 and I have an SYE and CV drive shaft.
I didn't notice it much before and it's definitely not an extreme angle or anything, but wasn't sure when I set everything in if I need to adjust the tranny mount to get it to point more at the yoke of the 8.8. I'm assuming I don't because of the CV but wanted to make sure before I have everything welded and bolted in place.
Thanks!
1995 YJ: 4.0L I-6 and AW-4 trans; CJ front clip; SOA front, 4-link in rear; 8.8 rear w/ Detroit locker; 4.56 gears; TJ front shafts; SYE; 1" Body lift; JB4x4 hi-steer; Ford Taurus fan; B&M Hi-Tek trans cooler; 35" Procomp MT on aluminum wheels
YJ43 is offline
post #2 of 9 Old 03-11-2012, 08:28 PM
mrmonkey
I'm actually glad to see I wasn't the only one. Mine was about 1/2" off... is that what you're finding? I just went through the same swap.
mrmonkey is offline
post #3 of 9 Old 03-11-2012, 09:02 PM Thread Starter
YJ43
Yep, it's not off by much, just due to the offset of the yoke on the 8.8.
YJ43 is offline
post #4 of 9 Old 03-11-2012, 10:25 PM
Flajeeper1
1987 YJ Wrangler
Should not an issue. The pinion is offset by approx. 2-3/16" to the right of center. The Dana 35 is approx. 3/4". I installed an 8.8 in my YJ and have had no problems.
Flajeeper1 is offline
post #5 of 9 Old 03-12-2012, 05:24 AM Thread Starter
YJ43
Cool, appreciate everyone's response. The PO installed the 8.8, and this is my first engine/trans swap. I figured it wasnt a problem but wanted to Check Didn't think about it or even notice until I had everything lined up.
YJ43 is offline
post #6 of 9 Old 03-12-2012, 07:14 AM
Sprungover
The CV shaft will easily handle the offset of the 8.8
Sprungover is offline
post #7 of 9 Old 03-12-2012, 07:39 PM Thread Starter
YJ43
Great, thanks for confirming!
YJ43 is offline
post #8 of 9 Old 10-07-2013, 08:02 PM
fishadventure
Related, but yet unrelated question: How did you locate your motor mounts? Mocking it up in place or measuring the offsets?
fishadventure is offline
post #9 of 9 Old 10-09-2013, 03:51 AM Thread Starter
YJ43
I mocked it up in place. I had motor/trans/tc lifted and aligned where everything fit best. I was going with the ford Taurus fan so I pushed the engine fairly close to the firewall. Not too close but just tried to maximize space for fan (it's still tight though). Made sure drive line was lined up and had someone burn the mounts in.
YJ43 is offline
sbc drivetrain swap ?s BionicOnion YJ Wrangler Technical Forum 1 10-21-2009 12:31 PM
Drivetrain swap lkg351 YJ Wrangler Technical Forum 1 01-09-2009 08:43 PM
Drivetrain Swap ? Black Hills TJ TJ Wrangler Technical Forum 1 11-18-2008 09:26 AM
xj drivetrain swap into yj gregslse YJ Wrangler Technical Forum 12 10-26-2008 08:47 PM
YJ drivetrain swap jeddy53824 YJ Wrangler Technical Forum 7 08-04-2007 09:47 PM
