Drivetrain Rattle in 4th & 5th - JeepForum.com
 8Likes
post #1 of 50 Old 09-03-2017, 06:24 PM Thread Starter
Louie4
As the title says, I'm hearing a rattling type noise when cruising in 4th gear at 40 mph and in 5th when cruising a little over that. I also hear it more when I downshift into those gears. It sounds like it's coming form the t-case or the AX-15. I'm not sure though which nor know of any sure fire diagnostics short of taking those components out. Here's some things I do know:
-Front driveshaft rebuilt
-Rear driveshaft rebuilt
-NP231 has a AA SYE not installed by me, but a buddy. Came out of a '95 YJ.
-AX-15 has well over 320k miles so who knows.
I wish I had a better description of the noise. It's to the point where I feel if I let it go there will be a failure, possibly catastrophic.
Some methods of diagnosis I had was:
Remove front driveshaft and drive it similarly
Remove rear driveshaft and drive it similarly
I also put the t-case in neutral and put the AX-15 in 4th and 5th and listened. I have no idea if that's a good idea or not. But I thought I heard the faintest sound of what I was hearing.
Any thoughts or idea?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #2 of 50 Old 09-05-2017, 06:51 AM Thread Starter
Louie4
Another idea that is probably less safe is to put the rear axle on jackstands and put the transmission in 4th and 5th. Maybe some load on it will present the problem.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 50 Old 09-05-2017, 09:55 AM
gotswap
Tcase chain loose and slapping around maybe?
gotswap is offline
post #4 of 50 Old 09-06-2017, 09:02 AM
bpounds
bpounds's Avatar
When "cruising in 4th or 5th", does changing the throttle make the noise change? What I mean is, does accelerating lessen the noise? Does decelerating change the noise?
Those actions would change the tension on the TC chain. If it rattles the same when climbing a hill as it does when coasting, probably not the chain. But it would be not too be a job to pull the rear case half and inspect the chain for slop and the case for sign of rubbing.
Does slightly riding the clutch change anything? Like TO bearing type stuff?
puppybreath likes this.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #5 of 50 Old 09-06-2017, 09:53 AM
cKruzer
cKruzer's Avatar
1987 YJ Wrangler
can you descirbe it better? is it a resonance rattle? a metall on metal rattle? drivehaft hitting a muffler rattle?
to my knowledge. bearing issues related to the trans input/output shafts will show up as vibes. loose chains show up like a knock or a valve tap (loud).
First thing I would start doing is getting my baseline for diagnosing. Is it speed related or rpm related? If speed, does changing rpms reduce or increase the noise? or no change? Does it still happen if turn the engine off and leave in gear? Does the pitch change allowing you to listen for the location of the noise while coasting and engine off?
1987 YJ - Aka; SpeedBump.
Target: 5.3L; AX15; NP231; D44/D60; 4.88s; 36s
הָיָה הָיָה הָיָה
YJOTM AUG '17
cKruzer is offline
post #6 of 50 Old 09-06-2017, 10:45 AM
mike134
How old are the engine and transmission mount bushings? It might just be vibration making its way to another component unrelated to drivetrain.
mike134 is offline
post #7 of 50 Old 09-06-2017, 06:28 PM Thread Starter
Louie4
Potentially. I think removing the front driveshaft and driving around will help tell.
So...the noise goes away (as best I can tell) when accelerating under load. It's most noticeable when letting off the gas and coasting in 4th. Not as bad in 5th. I have a locker in the front D30 which causes the front driveshaft to spin which leads to the t-case chain spinning.
It's speed related. 40 mph is where it's most noticeable...coasting in gear. I haven't tried killing the engine and listening yet. The noise is like a tap almost but internal. I'm leaning towards the t-case.
Engine mounts are Brown Dog, the trans mount is an aftermarket poly performance. I plan to get a new skid and change the trans mount back to stock. I don't think those are the culprits though.
My first instinct was the t-case. But I know it's not as old as my transmission...but I can't imagine a transmission making the noise I'm hearing. I would assume the transmission would eventually grind and squeal and have trouble shifting.
I will say, I do have some dark ATF on the seam of the t-case but when I pull the fill plug, ATF comes out. SO I know it's not low on fluid.
Next step is removing the front shaft.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #8 of 50 Old 09-06-2017, 07:40 PM
cKruzer
cKruzer's Avatar
1987 YJ Wrangler
Can you hold your phone down below the rockers while driving and record the sound?
הָיָה הָיָה הָיָה
YJOTM AUG '17
cKruzer is offline
post #9 of 50 Old 09-08-2017, 04:37 AM Thread Starter
Louie4
No.
Between the wind and tire noise...It would be a wash and with my luck I would drop my phone and drive over it.
Instead I unbolted the axle side of the front driveshaft and zip tied it to the frame. That doesn't sound good after typing it out but it's temporary. I wrapped the u-joint caps with duct tape. We'll see if the noise goes away.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #10 of 50 Old 09-08-2017, 06:19 AM Thread Starter
Louie4
Well, drove to work and it didn't make a lot of change in the noise. It's almost like a roaring noise at times. So, the front driveshaft isn't spinning which to me eliminates the chain. It also makes me think it's a bearing of some sorts.
At this point, maybe I should pull the cover off the t-case?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #11 of 50 Old 09-09-2017, 09:59 AM Thread Starter
Louie4
I drained the t-case. The fluid was dark but not burnt. I think I changed it a year or so ago so I may investigate it further.
At this point I can take the back half off the t-case or pull the whole thing. I'm leaning more towards the t-case because I have no issues shifting gears and no grinding from the AX-15.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #12 of 50 Old 09-09-2017, 12:12 PM
shaggyjim
shaggyjim's Avatar
I would say that you might as well pull the t-case and work it on a bench Louie. Another reason to drop it is if you find out its not in the tc and you deside to tear into the trany I find it easer to drop the trany with the tc off already.
Jim...
"That's more fun than watching a hippie get mauled by a bear!"
shaggyjim is offline
post #13 of 50 Old 09-09-2017, 01:01 PM Thread Starter
Louie4
Point taken. I will unbolt the shifter and driveshafts and drop it like it's hot.
shaggyjim likes this.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #14 of 50 Old 09-09-2017, 05:06 PM
shaggyjim
shaggyjim's Avatar
I feel your pain. I have to drop my tc Sunday as well to check for a slipping chain. Its like number six on my list of things to do tomorrow.
Jim...
post #15 of 50 Old 09-09-2017, 06:32 PM Thread Starter
Louie4
I hear ya. Mine is whenever I can spare some time. I have to put in spurts of time in between work and family time.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
