Drivetrain question - JeepForum.com
post #1 of 4 Old 04-04-2011, 12:17 AM Thread Starter
bananayellow
Drivetrain question
Just purchased a 1989 Jeep Wrangler 4.2l and I took it onto the beach and ended snapping some bolts that were attached to the rear driveshaft and I am planning to fix this ASAP. However before I put any new parts I was wondering if anybody knows what axles I probably have on here (presuming stock) and also what axles I could switch them out for with little to know fabrication or jerryriggin.
Thanks,
Paul
FIRSTPOSTYEEEEEEEEEEEEEEEEEEEAH!
bananayellow is offline
post #2 of 4 Old 04-04-2011, 12:18 AM Thread Starter
bananayellow
it's late... no not know.
post #3 of 4 Old 04-04-2011, 12:33 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Your Jeep came stock with a Dana 30 front axle & a Dana 35 rear axle.
It's likely that you just snapped the u-joint strap bolts. Easy fix.
The front axle is a good axle & there are cost effective upgrades available for it.
The rear axle is a turd and you should consider a Ford Explorer 8.8 upgrade if you ever have trouble with it.
Max
Sent from my HTC Incredible Droid
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 4 Old 04-04-2011, 07:39 AM
notmyj
Max pretty much hit the nail on the head as we know every YJ came with the D30 front and D35 rear axles. However, since I'm sure you will have more questions about your jeep (thats the whole point of this forum) we will need to know exactly what you got. So please fill out your profile. It really is important, and helps us help you.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
1989 , axle , dana 35 , drive shaft
Drivetrain swap question... jopolly3 YJ Wrangler Technical Forum 2 02-25-2009 08:06 PM
drivetrain question (when doing a 4.0 swap) what do i need? rolledthatho YJ Wrangler Technical Forum 4 02-20-2006 11:48 AM
Question: Drivetrain JQlaxTJ TJ Wrangler Technical Forum 3 10-15-2005 08:07 PM
Drivetrain Question..Need help Please. 97grntjsahara TJ Wrangler Technical Forum 1 09-01-2004 06:57 AM
TJ drivetrain question... MasterCujo TJ Wrangler Technical Forum 2 06-09-2004 10:16 AM
