drivetrain problem - JeepForum.com
post #1 of 6 Old 10-31-2011, 06:05 PM Thread Starter
anthonywrangler
drivetrain problem
I have a 1989 wrangler, and today on my way to work I heard a clunk........clunk.........clunk every 50 feet at around 70mph. I then pulled over to see what it could be, could not do a good check being that it was raining real bad. I then went to go in first gear and as I let go of the clutch nothing but rattling noise and the truck hardly moves. It will jolt forward real hard like I popped the clutch if I kept my foot on the gas. Got the truck towed to the house, and tried some trial and error. The drive shaft to the front wheel is not on (from previous owner). Shifter set to 2wd. NOW!!!!! When I put it into neutral or 4wd low (last one at the bottom) it will drive with no rattling/grinding noise but feel like lose of power like clutch is slipping. In 2wd or 4wd high it will rattle/grinding and won't move. I can fully let go of the clutch in first gear and it won't shut off. Your help is greatly appreciated!!!!!
anthonywrangler is offline
post #2 of 6 Old 10-31-2011, 06:52 PM
panaceabeachbum
sounds like its time for a clutch
panaceabeachbum is offline
post #3 of 6 Old 10-31-2011, 09:00 PM Thread Starter
anthonywrangler
You think? Because like I said when I change out of the 2wd to 4wd the truck will move. How does the transfer case effect the clutch?
post #4 of 6 Old 03-31-2013, 10:50 AM Thread Starter
anthonywrangler
It was the transfer case
post #5 of 6 Old 03-31-2013, 02:27 PM
YJames90
YJames90's Avatar
What was wrong with it?
My 2.5 to 4.3 swap thread
YJames90 is offline
post #6 of 6 Old 04-01-2013, 07:19 PM Thread Starter
anthonywrangler
I asume since i have a 4 inch lift and the tranny is dropped so i can still use the stock drive shaft (i bought the jeep like that)(and im new to the jeep world) caused the oil to leak out little buy little and ran it dry enought till it finally gave out. And i was running it on 2 wheel drive because the front shaft is not connected
Drivetrain problem liftedyj91 YJ Wrangler Technical Forum 11 03-05-2011 07:07 AM
Drivetrain problem. Have video.. BUSAFREAK TJ Wrangler Technical Forum 14 09-09-2007 12:33 PM
TJ drivetrain problem xtremebikr04 TJ Wrangler Technical Forum 3 10-16-2006 08:54 PM
Scary drivetrain problem. 40 Thieves YJ Wrangler Technical Forum 9 07-18-2005 10:51 PM
drivetrain problem nuk3r YJ Wrangler Technical Forum 7 06-26-2005 08:51 PM
