Drivetrain parts from my parts cheap compatibility - JeepForum.com
 1Likes
  • 1 Post By timatoe
post #1 of 7 Old 06-19-2017, 06:54 AM Thread Starter
ScottCassidy24
Hey everyone. I've just picked up a base model 95' YJ. 2.5L 4 cyl. Manual transmission. It passed emissions and safety inspection before I purchased it thankfully! For its age and being an Ontario jeep it's in reasonably good condition. Needs a few little things (temperature gauge isn't working and 4 low won't engage) but having this other jeep makes me think we could really beef this little 4 cylinder up.
My parts jeep 92' 6cyl automatic with half as many miles on it but with bad frame and tub. Needs a whole bunch of other work but drivetrain is in good shape..
What I want to do is swap transfer cases (or repair the one in the good jeep). transfer case won't engage neutral or 4 low in the good jeep. And Possible engine swap as the good jeep has double the miles and a 2.5 4cyl.
1. I believe all YJ jeeps used the same transfer case so should be interchangeable?
2. Transmission gearing... is it the same for I6 vs I4 engines? Would there be any problem keeping the manual trans and putting the bigger engine on it? Any need for adapters etc? Or will all the bolt holes line up.
Any helpful tips and tricks with regard to 4 to 6 cylinder engine swaps? I've never attempted any engine swaps/installations. Are all Motor mounts present on the 4cyl frame? How much of exhaust system will have to be swapped, will the different drivetrain components line up or will there be a need for adaptor plates etc.
I have a mechanical background. But I've never done an engine swap or drivetrain work before. I'm eager, and have most of the tools I think. And some friends who can help but I need to have the game plan in place and know exactly what's required.
Any links out there to other threads or YouTube videos are appreciated
Thanks everyone !
ScottCassidy24 is offline
post #2 of 7 Old 06-19-2017, 07:08 AM
johnboy68
HIP2BSQR
johnboy68's Avatar
Start here:
http://www.jeepforum.com/forum/f12/y...-specs-563403/
-John-
johnboy68 is offline
post #3 of 7 Old 06-19-2017, 07:49 AM
bruinjeeper
Motor mounts are present, but will need to be cut and relocated.
bruinjeeper is offline
post #4 of 7 Old 06-19-2017, 10:31 AM
timatoe
timatoe's Avatar
If it were me...... I'd pull the entire drivetrain, exhaust, wiring etc from the 6 cylinder donor and swap into the good frame 4 banger. Other than the new motor mounts, I wouldn't be trying to piece mill anything together, use everything that already works together. Keep the 4 banger axles, unless the 6's were already regeared better than 4.10.
project_mercy likes this.
timatoe is offline
post #5 of 7 Old 06-19-2017, 11:34 AM Thread Starter
ScottCassidy24
Actually the front axle has a cable style selectable diff lock, I haven't looked at it closely Unfortunately the doner jeep has busted shock mount on rear axle. Will have to check hearing and see. The doner is an hour away at my mother place where I had it up for sale. Will have to get it back to my place before I start tearing it apart.
The switch from manual to automatic transmission will undoubtedly mean more work. I'll have a look round and see. Otherwise I'll need the ax15. Which I would prefer but my wife would definitely be happier with the automatic trans.
post #6 of 7 Old 06-19-2017, 11:46 AM
puppybreath
Hold out for the AX15, less trouble in the long run
puppybreath is offline
post #7 of 7 Old 06-19-2017, 05:49 PM
Drednot
The axles in the four cylinder were 4.10 stock vs. 3.07(3.55?) for the six cylinder, so you are ahead of the game there.
I would keep the transfer case with the auto trans setup as you may have to swap input gears going to a manual. Keeping the whole six cylinder drivetrain intact will make things easier.
The fun part will be removing the motor mount towers and welding them in the correct position for the six cylinder
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35@3.07
12 Cherokee 4x4,3.7L,42RLE/MP1522, D30M/8.25@3.73
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
