Which driveshaft u-joints (8.8 & D30)
| RUBICON EXPRESS Lift Kits and Accessories Available at Bas | Spartan Lockers FREE SHIPPING Excellent Prices | Free Shipping on TIRES at KrawlOff-Road |
#1 | |
Been looking around trying to figure out which type of ujoints I need to buy to replace all my driveshaft (front and rear) ujoints. From what I've read it sounds like the front end typically has Spicer 1310's, but I can't find any info on what my rearend has (same thing all around perhaps?).
92 YJ. I have a Ford 8.8 in the rear with SYE, dana 30 up front.
#2 |
Yota Recovery Specialist
1310 spicer is what you need, me and a buddy are getting ready to do the same, i have a d35 but he has the 8.8. all is the same so you were right.
'90 I6 258 w/ Weber 32-36 Carb. 32" BF M/T's with cragar rims 5" BDS springs, MORE greasable shackles, XJ driveshaft, AA SYE kit, RE SS brake lines. Bilstein 5150's, 255/70 valving all around, 14" travel in front, 10" in rear. ~Enjoy>>> http://youtube.com/watch?v=nQCIXoBqpc0 JF MOTO>>>>"Ban a tard...save a life" <<<contributed by leftlanetruckin OMNIPOTENCE...gotta get me some of that |
#3 | |
1310's everywhere, UNLESS your adapter flange for the 8.8 is a 1330 or something like that. make sure to get the right ujoint for it. mine is 1310, but there are some others floating around too |
#4 | |
#5 |
I thought I read somewhere that the 8.8 Explorer flange adapter had 1330's in it stock. When comparing it to my stock U-joint that I had in my D35, it looks like it will fit it perfectly.
What is exactly different between the 1310 & 1330, just larger overall?
Sold 90' YJ, 4.2, Weber, 4" Procrap, 33" BFG MTs, 8.8 w/ 4.10s & LSD, SYE & Tomwoods DS, Dual Optimas, Jacobs, Electric fan. 97' ZJ, SOLD |
#6 | |
Now the problem is figuring out if the driveshaft yokes were converted to the 1310 type when installed on the Jeep and how to tell the difference. |
#7 |
1330 has a larger cap diameter with a wider spread...
-scotty 98 TJ 4.0 (Geared and locked on 2" coils and 33x10.50's), Former YJ/XJ/WRX Builder...
Contribute to my YJ spring rate info thread! |
#8 | |
yup, what he said. you should just be able to measure and tell the difference. ![]() |
#9 |
Sweet thanks guys, I will probably just yank the driveshafts and measure away. I have some movement in a few of the joints and its time to replace them. First time servicing driveshafts myself so it should be fun.
#10 |
The 1310's are 3 7/32" from bearing cap to bearing cap.
The 1330's approx 3 5/8" from cap to cap. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
