#1 | |
Driveshaft U-joints
Ok...so i'm putting in my 8.8, and wanted to change out my u-joints.
i cant get the rear rear driveshaft u-joint out. i've got it propped up, beating it w/ a hammer. i've got it disconnected from the pinion (and there were no needlebearings OR grease in the unjoint, btw). but i propped the ds up on a jackstand and block of wood, and pounding it with a hammer but it wont budge. any suggestions? the slip yoke is still in the tcase... (pulled it out once accidently....then stuck it back in before too much fluid leaked out, but i've got more fluid on hand if it's better to just pull it out). so.... i dont have any idea. it doesnt seem to want to budge.+ help? ![]()
#2 | |
H2 Recovery Team Member
RIP: '88 YJ 2.5L Ax-5 NP231 Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front. 92 YJ 4.0L Ax-15 231 5" springs, 1" shackle 31's or 35's depending on my mood |
#3 | |
I just got a big c-clamp and started using that and a socket to force it out, it moved a little bit. but i guess i'll go ahead and pull the driveshaft out. is there anything i need to know about putting the slip yoke back in the t-case? or does it just slide back in? TIA |
#4 |
The slip will just slide right back in.
These aren't necessarily driveshaft u-joints exactly, but a u-joint is a u-joint so these two writeups of mine might help give you some tips: Changing Wheel joints Rebuilding a CV Driveshaft
95 YJ: SOA, locked 44, locked 8.8, 37s, beadlocks, OBA, winch, and a few other things. [URL=http://www.cdmfabrication.com/aboutmel.html]My Build-Up Post[/URL] -- [URL=http://www.cdmfabrication.com/kbl.html]SWB FAQ[/URL] -- Mike |
#5 |
Thanks, you guys were a lot of help. I ended up getting 'er out!
I'll put the new ones in tomorrow. but again, thanks! ![]() |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
