driveshaft and SYE - JeepForum.com
post #1 of 4 Old 04-11-2013, 08:30 PM Thread Starter
kjg26
kjg26's Avatar
driveshaft and SYE
when installing a SYE obviously the stock driveshaft will not work. Until earlier today I assumed the only solution was a DC(double cardigon) shaft was the only option. Someone mentioned using a shaft with single u-joints on both ends with the slip in the middle. This makes sense for smaller lifts, at least in my head. I'm working with about 3 in of lift on my 93 YJ. Which set up should I go with. Pros/cons of each? Or am I completely flawed in my thought process. Everyone seems to go with the DC shafts.
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #2 of 4 Old 04-11-2013, 09:30 PM
SamzJeep
Hey 26, I'm pretty much doing the same thing within the next few weeks (SYE and DC drive shaft). I have an '88 YJ and recently put in an AX15/231 TC out of a '97 XJ. I've had them for about a year and just got around to putting them in. I've done a lot of reading/searching reference the SYE/DC. It seems to be what you need to do...if you put a SYE, then you need/should put the DC. You'll also have to get your pinion correct. There's a few posts on this forum that pretty much walk you through it. It's best to do it right the first time, instead of trying something that will likely not work very well. I finally put in my 4" lift last week and I'm doing other things as I'm waiting for parts to show up at my door (UPS). The DC I'm going to be using is actually a front drive shaft from the same XJ I got my tranny/TC out of. I'll be taking it to a driveline shop to have them shorten it and balance it. I won't be able to do that until I take my TC drop out and set the pinion, so I can get the correct measurements for the DC drive shaft. Do more searching on this so you don't run into problems. I hope this helps....good luck....
SUPPORT OUR TROOPS
SamzJeep is offline
post #3 of 4 Old 04-11-2013, 11:36 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Sam has the right idea.
Luck Favours The Prepared
Anticanman is offline
post #4 of 4 Old 04-12-2013, 10:25 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
THIS
http://www.pirate4x4.com/tech/billav...ft/index2.html
YJ 350TPI NV4500 HPD60 14BFF ARB Chromo's
March 2017 YJOTM
87TPIYJ is offline
