driveshaft to rear d35 - JeepForum.com
post #1 of 8 Old 04-25-2012, 07:46 PM Thread Starter
91YJ-98TJ
i was wondering how to replace (or if i have to take it to someone) the seal and bearing in the front of my dana 35 because it just started leaking pretty good and i can feel a little vibration back there. if i can do it myself i will but i dont really know much about dealing with gears but am willing to learn
91YJ-98TJ is offline
post #2 of 8 Old 04-27-2012, 10:31 AM
Come On Comet
I don't think a pinion seal replacement is for beginners. You have to torque that bolt to a certain amount and that involves checking the drag with no carrier installed to be correct.
I know many just zip the nut back on but torque it wrong and you’re rebuilding your diff.
Come On Comet is offline
post #3 of 8 Old 04-27-2012, 10:35 AM
Ripper3494
you need an inch/pound wrench to measure the rotational force it takes to spin the carrier with the tires off, then when you put the nut back on you wanna torque the nut untill it takes the same force to rotate it... or you can just take an impact and go for it but you risk having to rebuild ur diff again very soon
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #4 of 8 Old 04-27-2012, 10:35 AM
Ripper3494
btw when i do mine i just use an impact but i'll never do that on anyone elses rig or tell anyone else to do that. ive never had any problems but theres always that chance
build thread:
RC vs BDS
post #5 of 8 Old 04-27-2012, 11:16 AM
giggityjeeper
lol was just thinking the same thing, I did mine twice and impacted it back on both times, this is not right by no means, but worked for me each time, and prolly will most of the time, but ya always taht chance
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #6 of 8 Old 04-27-2012, 11:19 AM
glenn-91YJ
glenn-91YJ's Avatar
Definitely not a beginner project. To see what's involved here's a pretty good video. It's not a Dana diff but you'll get a good understanding of what's involved.
Owning a "Renegade" means being "Different"!
"The greatest danger to American freedom is a government that ignores the Constitution."
-Thomas Jefferson
glenn-91YJ is offline
post #7 of 8 Old 04-27-2012, 12:15 PM
Siva283
To change the pinion seal I only ever had to take the nut off the yolk and slide the yolk off. Doesn't that bolt only effect the yolk itself? I thought there was another nut behind that that needed the pre load. Am I wrong?
Ask me how I know...
Siva283 is offline
post #8 of 8 Old 04-27-2012, 12:35 PM
giggityjeeper
^^ I think you right, not 100% sure, I never worried about it when I did mine, I impacted it on and torqued to specs and all was good, not a differential wizard, tearing abart those this week so should be a good lerning curve... woot
dana 35 , leak
DIY XJ front driveshaft shortening for use as rear CV driveshaft on YJ Joe Dillard YJ Wrangler Technical Forum 43 08-12-2014 07:53 PM
Use a TJ front driveshaft for rear driveshaft?? JeSimmers TJ Wrangler Technical Forum 4 01-30-2013 02:45 PM
Questions about shortening a Cherokee front driveshaft to make a rear CV driveshaft AnonymousD YJ Wrangler Technical Forum 19 04-19-2011 09:10 PM
Rear Driveshaft ? apexjeepinjoe TJ Wrangler Technical Forum 9 02-24-2008 09:47 PM
Rear driveshaft change when changing rear axles? skifast1 TJ Wrangler Technical Forum 7 12-23-2004 08:36 AM
