driveshaft noise on 2000 Wrangler - JeepForum.com
post #1 of 5 Old 12-13-2001, 08:31 AM Thread Starter
tglenco
Have a 2000 Wrangler Sport that makes a very strange sound on occasion. Those occasions being right after the car has been running at highway speeds (50-60MPH) or when it is on an incline. A "torque-ing" noise (like you are overtightening a screw ?) is heard from the driveshaft close to the rear differential. Doesn't always occur but enough that it makes me worry that the driveshaft is not true or that something is amiss where it enters the differential. Any ideas anyone ?
tglenco is offline
post #2 of 5 Old 12-21-2001, 06:58 AM
MKB
Your 2000 Wrangler is a TJ not a YJ. Your in the wrong forum.
Some people,
94 YJ 2.5, 5 spd
PerformanceAid Throttle Spacer
K&N w/ Turbo Tube
Swaybar Disco's
2.5" Spring Lift w/1.25" HD Shackle
1" Body Lift
4.56 gears w/ Rear Detroit Gearless
31x10.5 Nankang Radial A/T
15 to 20 Gal tank conversion
Warn 9000LBS
Dual Batt and 150 Amp Alt
Home-made Front&Read bumpers
Hard & Soft tops
MKB is offline
post #3 of 5 Old 12-24-2001, 08:21 AM
I-be-jeepin
WARRANTIE
'95 YJ 4.0 H.O
3"lift
32 11.5 Goodyear MT/R on aluminum
Turbocity air tube, exhaust, and throttlebody
I-be-jeepin is offline
post #4 of 5 Old 12-24-2001, 08:22 AM
I-be-jeepin
WARRANTY
'95 YJ 4.0 H.O
3"lift
post #5 of 5 Old 12-25-2001, 03:05 AM
Sarge37
Yea no respect from this forum. Do like they say take it in to the "Dealer" When your Warranty runs out, check back with us.
"If It Aint Broke, Fix It Till It Is!!!!!"
05 TJ Rubicon, 4.0L, 6 Speed.
07 Ram 1500 Quad Cab
Sarge37 is offline
Still Getting Front Driveshaft Noise Wrangler_91 TJ Wrangler Technical Forum 17 09-02-2011 10:36 PM
driveshaft noise? cant figure it out? MC_NickP TJ Wrangler Technical Forum 12 03-18-2009 10:02 AM
2000 TJ noise. Aretelio TJ Wrangler Technical Forum 3 10-19-2006 01:42 PM
Driveshaft noise, great, now what? What The? TJ Wrangler Technical Forum 16 12-13-2005 06:44 AM
Using a Soft-Top From a 2000 Wrangler on a 1998 Wrangler? Nighthawk TJ Wrangler Technical Forum 3 06-05-2002 05:02 PM
