Driveshaft length - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Driveshaft length
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineZONE 4.25" combo lift for TJ available at Rockridge4wFLASH SALE! Open thread to reveil the Newest Sale @ ROCKRI
Unread 04-08-2015, 05:24 AM   #1
miami30141
Driveshaft length
I have a 89 YJ with 4" lift and 1 1/4 shackles and I found a driveshaft for a good price and I have not had a chance to put my Advance Adapter Sye on yet so I dont know the correct length I was wanting opinions on if shaft will work Measuring from the center of the output u joint to the end of the 8.8 flange it's 21 3/4 extended and 18 1/2 compressed he said it was on a 95 YJ with 3.5 lift. Thanks for any help.
miami30141 is offline   Reply With Quote Quick reply to this message
Unread 04-08-2015, 06:42 AM   #2
calvynandhobbs
Personally, I would get the SYE installed and get an accurate measurement, but if you are getting it for a great price and not just good you could pick it up and have it lengthened or shortened if you need to once you have the SYE in for less than the full price for a new shaft.
94 YJ - work in progress
calvynandhobbs is offline   Reply With Quote Quick reply to this message
Unread 04-08-2015, 07:02 AM   #3
miami30141
Ok thanks
