driveshaft length - JeepForum.com
post #1 of 6 Old 09-20-2011, 12:45 AM Thread Starter
rshepler217
driveshaft length
i recently did the 4" rough county lift in my 95 yj and still have to put the transfer case drop bracket and sye in and plan on doing this on friday. i have a hill and rti event at my school on sunday and want to run both my jeep and truck but still need to have the driveshaft cut down. has anyone done this exact set up and know the driveshaft length so i can have it cut in advance?
rshepler217 is offline
post #2 of 6 Old 09-20-2011, 05:12 AM
dadstoy
What motor? What tranny? I have a 4.0/AW4, rear axle moved back an inch, and my rear drive shaft is 14 1/2" long u-joint to u-joint........Need a little more info on your rig
dadstoy is offline
post #3 of 6 Old 09-20-2011, 07:50 AM
nzpete
If you are going with the SYE you won't need the transfer case drop. I hate those things. To do this correctly, you'll need to install the SYE and then measure the distance from the yoke at the SYE to the yoke on your differential, then have the driveshaft cut to fit.
To me, RC is kind of the Harbor Freight of springs. Sometimes you get a good deal and sometimes you don't.
nzpete is offline
post #4 of 6 Old 09-20-2011, 09:29 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
why would you run a t-case drop and SYE?
And I would never spend the money on a driveshaft with out measuring it myself. you have a small margin of error.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #5 of 6 Old 09-20-2011, 03:59 PM Thread Starter
rshepler217
its the 2.5 with the ax5 and np231. and thats why i wanted to know if anyone did the exact same set up and if not im just going to have to wait and measure it myself and just hope that the driveshaft gets done in time
post #6 of 6 Old 09-20-2011, 04:53 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Drop your driveshaft off at your local shop and keep them on standby when you can get the measurement to them.
Luck Favours The Prepared
Anticanman is offline
Driveshaft length wpparker TJ Wrangler Technical Forum 6 11-08-2010 07:37 PM
Driveshaft Length bamato YJ Wrangler Technical Forum 12 05-25-2007 04:12 PM
SYE/CV and Driveshaft length. gravitypastor TJ Wrangler Technical Forum 12 02-27-2007 10:51 PM
CV driveshaft length Texas TJ TJ Wrangler Technical Forum 1 04-10-2006 11:02 AM
