Driveshaft Grinding - JeepForum.com
post #1 of 4 Old 04-08-2010, 11:43 AM Thread Starter
thegreatnardini
Driveshaft Grinding
Hi there -
I was driving on the highway yesterday when all of a sudden the Jeep started vibrating and making a horrible grinding noise. I made it back home and checked underneath and this is what I found where the slip yoke connects to the rear drive shaft:
What do you think could be the cause of this? U-joint failure? they seem ok but I'm no mechanic so I could be missing something. I have a 1.5" lift on the Jeep, and although it came with a transfer-case drop kit I never installed it and haven't had a problem for the two years the lift has been on. Does the drive shaft angle look too extreme? I'm thinking about installing the transfer-case drop kit just to be on the safe side. I'll definitely have to replace the slip yoke and U-joints, just not sure what else needs to be done to keep this from happening all over again.
Thanks for your input guys
thegreatnardini is offline
post #2 of 4 Old 04-08-2010, 11:45 AM
1997_Sport
Just replace the ujoint and see if it helps.
1997_Sport is offline
post #3 of 4 Old 04-08-2010, 01:02 PM
Louie4
"You pass butter"
Louie4's Avatar
Yep looks like the u-joint needle bearings have wore out and the whole joint has shifted causing it to bind.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #4 of 4 Old 04-08-2010, 01:40 PM
djsmith1174
Just looks like a massive u-joint failure. It happens on occasion. Sometimes the cross will break and the driveshaft will just flop around and smash the floorpan. I doubt that the small lift is compromising your driveshaft angles. Did you notice any vibration prior to the failure? If you did you can always lower the Tcase an inch to alleviate that. If not, just replace the slip yoke and u-joint and chock it up to mechanical failure. If the wear on the driveshaft is too severe, you may want to replace the whole thing. It can easily be thrown out of balance causing vibration and premature failure in the future.
djsmith1174 is offline
DIY XJ front driveshaft shortening for use as rear CV driveshaft on YJ Joe Dillard YJ Wrangler Technical Forum 43 08-12-2014 08:53 PM
Grinding? SFJeep89 YJ Wrangler Technical Forum 9 12-31-2008 06:09 PM
grinding second bybsurf21 TJ Wrangler Technical Forum 15 01-21-2008 04:58 PM
Too much grinding that_1_guy YJ Wrangler Technical Forum 2 07-15-2006 02:14 AM
A/C grinding his15153 TJ Wrangler Technical Forum 3 12-09-2005 05:52 PM
