Driveshaft experiment/ sye purchase. - Page 2 - JeepForum.com
post #16 of 69 Old 11-17-2013, 04:39 PM Thread Starter
Springer45
Front. I don't think this one is the problem
Springer45 is offline
post #17 of 69 Old 11-17-2013, 07:03 PM
hotcobra03
What speed does it start at...you said higher..
How about in 4 wh high? Does it still do it?
Nothing jumped out on pics as to major angle off..
Your description of how it comes and goes sounds like tc noise..
Major drive line issues should show at low speeds. 25-45..
Im assuming you got it this way just didnt notice at first..
hotcobra03 is offline
post #18 of 69 Old 11-17-2013, 09:29 PM
linusb
Originally Posted by Springer45
Linusb, I remember when my rear end went out on my ford that it was leaking like crazy and had a tend any to lock up when I came to a near stop. It seems as though, after experiencing a rear end going bad, a rear end has a tendency to show signs of wear at slower speeds. And from what I've researched it seems like driveshafts vibrate at all speeds but it becomes most noticeable at higher speeds? What makes you so sure that it's a driveshaft thing? What's the difference in signs of issues between the two?
Hey Springer- with the amount of lift and description that the auto tranny is longer than manual , I was diagnosing most likely problem first.
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #19 of 69 Old 11-17-2013, 09:32 PM
linusb
Pinion angle looks to high to me. Put an angle finder on DS and pinion.
linusb is offline
post #20 of 69 Old 11-17-2013, 10:45 PM Thread Starter
Springer45
The noise doesn't exactly come and go here and there. It's hard to explain.
The noise starts at Lower speeds like 25 mph but isn't intense. It really gets loud at 60-75 mph.
I've never tried using 4wd high on get freeway to see if it makes the noise. Are you guessing it will be louder? Or possibly go away? The tcase never made noise before I did the lift do unless the tires or driveshaft angle are putting more pressure on the tcase I don't think that would be my problem. But I may be wrong. My first suspicion would be the things that changed.
Linusb that angle finder sounds like a good idea. I didn't know they even made one. What am I looking for on a ds angle finder? What's the ratio that is appropriate? Could a suspension place do this? Would they probably charge me or is it easy?
post #21 of 69 Old 11-18-2013, 08:14 AM
hotcobra03
Im on cell cant post much..
Go to spicer.com
Look in literature. .jp300 Its driveshaft parts..I did these for 20 yrs.
You will see also how to check angles
Your rear to me doesnt look like 8.8..it has a jeep rear pinion yoke with straps..
Ford used ubolts or flat flange..
Books on rear are also in this link...
My son just got a 89..I will post pic of his rear shaft.. you tell me what you see wrong..it stands out
post #22 of 69 Old 11-18-2013, 08:47 AM
Randonexplosion
Deplorable
Randonexplosion's Avatar
I'm not sure on your noise, sounds like it could be several things. Are your U joints fine?
Your pinion angle is too high for your slip yoke setup. You can go to Autozone or Napa and grab a magnetic angle finder for $5 or so. I would start with removing the shims that came on the springs.
Randonexplosion is offline
post #23 of 69 Old 11-18-2013, 09:03 AM Thread Starter
Springer45
Hotcobra03, Not sure where the 8.8 thing came from. But if you could post pics that would be great. It sounds like this will be a good learning experience for me. Thanks guys. I appreciate the site reference I'm sure that will help.
post #24 of 69 Old 11-18-2013, 10:10 AM
hotcobra03
Ours makes loud banging noise if you brake very heavy ..and thats an 8.8 in a 95 f150 4x4
post #25 of 69 Old 11-18-2013, 10:24 AM
hotcobra03
Heres a link for some pics..jeep has some crazy stuff..
Its like they have been chasing problems to..
http://www.driveshaftspecialist.com/Truckhtml/Jeep.html
post #26 of 69 Old 11-18-2013, 10:32 AM
hotcobra03
http://www.dennysdriveshaft.com/
Heres another..
So much has changed over the years
post #27 of 69 Old 11-18-2013, 06:07 PM Thread Starter
Springer45
Go to spicer.com
I'm on a cell as well... I feel your pain. Are you saying your sons 89 is correct and mine isn't and my problem stands out or your sons is wrong and I'm supposed to understand what's wrong from the lesson learned on his?
post #28 of 69 Old 11-18-2013, 06:12 PM Thread Starter
Springer45
Based on this diagram my pinion should be lower and if I had a cv driveshaft it should line up straight? Hotcobra03 is this what ur trying to say is my pinion should have a upward angle do when I hit a bump or something it flattens into the ideal did angle instead of resisting it?
post #29 of 69 Old 11-18-2013, 06:18 PM
Jeffro06
Jeffro06's Avatar
Stock drive shaft needs to have the pinion parallel to the output shaft.
CV drive shaft needs to have the pinions pointed at the output shaft, minus about 1 or 2 degrees.
If your stock drive shaft is now too short, which I fear it is, the angle's on the u-joints will be more than they can handle.
Jeffro06 is offline
post #30 of 69 Old 11-18-2013, 06:30 PM Thread Starter
Springer45
I got measurements 17 rear 14 did and 11 tcase yoke. From my understanding the first and last should be the same? What is the most drastic angle my ds can be at without problems?
"If your stock drive shaft is now too short, which I fear it is, the angle's on the u-joints will be more than they can handle." Jeffro06
What would you do given the angles I just posted? Am I screwed should I just get a sye and cvdriveshaft? If so should I leave the shims on the leaf springs? Or take them off and check my angles after install?
