Driveshaft - to balance or not to balance??? - JeepForum.com
post #1 of 8 Old 09-08-2009, 12:29 PM Thread Starter
brtt485
Just finished the SYE install on my YJ and had an XJ front shaft cut down to length. The stock u-joints (no idea how old they are) seem to be in good shape. The jeep is not my DD but it does get highway use to and from the trail.
My question is do I need to have the driveshaft balanced and if so does it matter if I have it balanced with the stock u-joints and then replace them later or should I replace them and then have it balanced???
Local shop wants $75 to balance the shaft and if I do that and add up the cost of buying the XJ shaft, having it shortened, new u-joints/centering ball, etc.. I could have almost just purchased a new Tom Woods shaft!
Also, if I am replacing the u-joints what should I be doing with the centering ball? Replace? Repair kit? I am new to CV shafts!
brtt485 is offline
post #2 of 8 Old 09-08-2009, 01:15 PM
1998zj
I didn't balance mine and it has no vibrations.
"Our lady of blessed acceleration don't fail me now"
1998zj is offline
post #3 of 8 Old 09-08-2009, 01:59 PM
jbeebe
yea i mean, if you're not getting any vibes then no need to balance. if the ujoints are in good shape it's up to you whether or not you want to replace them just for the extra assurance.
jbeebe is offline
post #4 of 8 Old 09-08-2009, 02:57 PM
Louie4
I say if you went through the trouble of cutting it down, why not balance? You might as well do it right if you're going to do it. I had my front one balanced for about $52. The guy also painted it, straightened it, and lubed the u-joints. I would also replace the centering ball and u-joints if you can.
Just my 2 cents though.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #5 of 8 Old 09-08-2009, 03:51 PM
93jeepyj
That sounds a bit high. I have a tom woods shaft and I just put in a 44 rear which required me to shorten the shaft over an inch. The telescoping part apartently god some mud in it and seized up at some point which I didnt notice until I pulled it apart. I sent it back to tom woods and they cut it down, balanced it, replaced two u joints, a couple seals and took care of the binding issue for 105 bucks shipped back to me. A local guy wanted 65 just to cut it down and fix the binding which he apparantly couldnt after a week and gave it back to me. I payed 330 for it new a few years back which seemed a bit steep at the time but its definatly a quality piece.
93jeepyj is offline
post #6 of 8 Old 09-08-2009, 04:46 PM
dbikers
no need to balance unless you have a lunchbox locker or 1 piece axle (no vac disconnect) as the ds shouldn't turn unless you're in 4wd.
STUPID HURTS.......OUCH!@#$
dbikers is offline
post #7 of 8 Old 09-08-2009, 05:19 PM
timatoe
timatoe's Avatar
I'm pretty sure he's talking about the rear shaft.
OP, you're probably ok if there's no vibes now. I woulda just had it balanced when it was cut down though. And no it doesn't matter if you change the u-joints after it's balanced.
timatoe is offline
post #8 of 8 Old 09-08-2009, 05:32 PM
dbikers
HA, i think that i've been hittin' the bong a little too hard.
jk, i have front ds on the brain and i need a balanced one (aussie locker)
dbikers is offline
driveshaft out of balance Ares YJ Wrangler Technical Forum 6 09-09-2012 07:42 PM
Balance front driveshaft myself??? WSTOF7 YJ Wrangler Technical Forum 15 01-29-2010 08:17 AM
Yet another driveshaft balance question. sitdwnandhngon YJ Wrangler Technical Forum 5 09-24-2008 09:43 PM
Out Of Balance mdot TJ Wrangler Technical Forum 6 07-10-2006 04:20 PM
Out of Balance EricS TJ Wrangler Technical Forum 10 09-25-2003 06:01 PM
