Driver's side brake caliber stuck on the way to work, no tools, what should I do? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Driver's side brake caliber stuck on the way to work, no tools, what should I do?
1999-2004 Jeep Grand Cherokee Shock Absorber (Set of 4)- G1993-1998 Jeep Grand Cherokee Front & Rear Shocks - GR1995-1998 Jeep Grand Cherokee Front & Rear Brake Pad &
Unread 06-21-2010, 12:05 PM   #1
sloan74
On the way to work during lunch driver's side brake stuck. When I pulled in and stopped - smoke, smell, whole nine yards....
I do not have my tools.
Should I just risk it and limp it home later this afternoon? It's only 9 miles back to the house. No interstate thank goodness so no heavy braking.
Just put new rotors and pads on also.......
Hopefully I can still salvage those and just replace the caliber...
I now officially hate mud. Never again will I mess with deep mud. Never again....
Water and red clay mud has officially now took my clutch, starter, and now possibly this.....lol
sloan74 is offline   Reply With Quote Quick reply to this message
Unread 06-21-2010, 12:12 PM   #2
sloan74
I thought I got all the mud out....went back outside and was looking at it - mud is still in there.
Rotor/pads look ok. I will limp it home and see if I can clean it real good before buying anything. Maybe I will get lucky and the caliber/pad is just compressed with dried mud/sand.
Unread 06-21-2010, 12:15 PM   #3
Que89YJ
If you drive it your calipper maybe the worst of your problems. I dont know how bad they are stuck but you generate a bunch of heat when you brake. Driving against that much friction if the calipers are stuck full on could give you more than heat it could give you flame. Get a bunch of water if you aere thinking about driving it home. Stop and quech it. If its stuck full on though I wouldnt risk it.
Que89YJ is online now   Reply With Quote Quick reply to this message
Unread 06-21-2010, 12:20 PM   #4
Louie4
I would take it easy on the way home and if it really starts to drag pull over and let it cool. I would do that a few times until you get to the house. I powered through my stuck caliper about 4 miles a year ago. Had it all replaced in an hour and a half.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Poison Spyder Fender Install
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline   Reply With Quote Quick reply to this message
Unread 06-21-2010, 12:21 PM   #5
michaelbarry
Don't have any kind of jack and lug wrench? Anyone else you work with have one you could borrow for the evening? Do it in the parking lot after work..that's what i'd try to do instead of driving it home if it's locked.
michaelbarry is offline   Reply With Quote Quick reply to this message
Unread 06-21-2010, 12:21 PM   #6
Louie4
Be careful not to crack anything if you throw cool water on it.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Unread 06-21-2010, 12:22 PM   #7
Que89YJ
LOL that may be the smallest of his issues if that thing goes up in flames.
Unread 06-21-2010, 12:24 PM   #8
sloan74
Yeah left the high lift jack sitting in my garage....if I had that, my tire iron and a screw driver I could at least pry it off the rotor.
Autozone is 1.5 miles from work, but it's in the opposite direction....
Unread 06-21-2010, 12:30 PM   #9
michaelbarry
No one can run by the house and get it for you? Ol lady at home to bring it? I'm sure most every co-worker at your place has the factory jack in their car. If it's not tall enough, Use a few wood blocks or something..you're not gonna be going real high with it. Lay your tire and wheel down under the Jeep with some scrap (insert favorite blocking material here) on top of it as a 'jack stand' in case the jack was to give way. That's just the way i'd go about it. I've had a lot of practice at improv repairs though. I ride/drive old junk.
Unread 06-21-2010, 12:33 PM   #10
sloan74
ole' lady is not an option....my last 4 wheel trip did too much damage.....she will flip if I call her up right now and tell her something else is wrong...
I am going to have to "hide" this one...
haha
Unread 06-21-2010, 12:35 PM   #11
sloan74
buddy at work has a 4x4 Ford Ranger. I will use his kit to jack it up this afternoon.
Unread 06-21-2010, 12:35 PM   #12
michaelbarry
haha
Even more reason to do it in the parking lot after work. "Hunny, i'm gonna be working a little late this evening." And ya ain't even lying!
Unread 06-21-2010, 12:36 PM   #13
YJake
Happened to me one day 15 miles from home but with BOTH calipers.
I just drove it home in 3rd/4th gear going 55mph She was a Smokin' at every stop but I had no choice. It made it home where I peeled the calipers off and bought new ones. (Make sure that the pistons in the new ones are phonelic(sp?)). DO NOT splash cold water on those rotors! It may cause them to crack if hot enough!
My rotors were fine, as were my new brake pads, just needed to replace the calipers is all. Oh, and MAKE SURE that the part store gives you a Left and a Right and not two of one or the other (There is a difference). I hear people complaining about that a lot on here.
Have fun and be safe!
P.S. I Hate Mud!
Jake
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline   Reply With Quote Quick reply to this message
Unread 06-21-2010, 12:37 PM   #14
sloan74
LOL SO TRUE
Already told her I was meeting her and the kids at the neighborhood pool right after work.....
Both wheels? MAN....Yeah I def would not splash water. You could crack all kinds of stuff....
The pads and rotor looked fine. I might just go buy a new caliber for the heck of it. It's only 20 bucks. "baby you need anything at the "grocery" store".....
Just bad timing. JUST installed a new starter last night...hehe but hell, it's a jeep, this is what is suppose to happen.....and yeah man, last of the deep mud and water for me. It ain't worth it...it's like getting very drunk - the night of the party its awesome, but the next day it's hell....
Unread 06-21-2010, 12:38 PM   #15
michaelbarry
LOL SO TRUE
I think you'll need more luck on not getting in trouble over that than you will on getting the brakes fixed. Good luck!
