drivers front universal joint removal - JeepForum.com
post #1 of 8 Old 05-28-2013, 06:05 PM Thread Starter
bigboss408
i'm looking for some pics on how to remove the diverside front universal the old one is clicking,
bigboss408 is offline
post #2 of 8 Old 05-28-2013, 06:16 PM
RustedWrangler
No pics for you, but you will need to remove the axle, so wheel off, hub bearing off, 36mm nut that holds axle in place on hub bearing off remove axle then replace the ujoint. You can do the whole thing in less than an hour if you have everything you need on hand when you start.
www.RCPFA.com
RustedWrangler is offline
post #3 of 8 Old 05-28-2013, 06:23 PM Thread Starter
bigboss408
do i need to replace the oil seal or bearing
post #4 of 8 Old 05-28-2013, 09:05 PM
fratis
fratis's Avatar
4.5" angle grinder with cut-off wheel.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #5 of 8 Old 05-29-2013, 07:17 AM
Firefyter-Emt
This is the BEST way to remove a U-joint by far! I have used this trick for years and its amazing!
Firefyter-Emt is offline
post #6 of 8 Old 05-29-2013, 08:55 AM
Old4X
1990 CJ7
There is a write up on it. THe trick to popping the hub loose with a socket is clearly shown.
Easy job, no seal to replace, just don't drag the axle stub across the seal.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #7 of 8 Old 05-30-2013, 06:32 PM Thread Starter
bigboss408
is there a link showing this trick
post #8 of 8 Old 05-30-2013, 06:46 PM
Old4X
1990 CJ7
YJs are old. Everything you have to fix has already been done and likely recorded in the FAQs,
Look here:
http://www.jeepforum.com/forum/f12/a...a-30-a-360209/
Old4X is offline
